~SlideWays~ wrote:I've got a t28 which is going onto my 4agze, currently it has a t25 with no water cooling.
What I need to know is:
- Where to get the correct fittings for the threaded water cooling holes of the t28?
- If I plumb this into the top and bottom radiator hoses will this suffice?
- How do I know what size oil feed restricter to use to suit this turbo (s15 model)?
- This turbo only has a flat flange for the intake, where could I buy the correct flange with round pipe and sealing rubber ring, etc. Would any old turbo place have this?
Thanks in advance.
~SlideWays~ wrote:
Yep If I can find the vernia (sp?) I'll measure it tonight. I had a look at the turbo after I posted this thread and it looks like there is a built in oil restrictor anyway. What sort of results did you get with this turbo (what sort of setup?)?
flygt4 wrote:i believe they can push around 200kw atw with the right fuelling and management. and enough boost....
Akane wrote:200kw at wheels with a T28 is totally pushing it. There are other people thinking it can do more, ie: "My cousin's brother got a T28 and it's good for 250kw au!", yeah, probably on a hub dyno :/ Not on a rolling road.
