Low_Aa63 wrote:yeah but its still not big enough for what im doing and rather than get a custom tunnel faricated i would rather find a factory rear wheel drive toyota thats around the same length in wheel base and use that tunnel.
Low_Aa63 wrote:cool cheers for that.. its for a 3sgte rwd into a st183, i was allready planning on using the subframe from an st185 just querying(sp) the tunnel thing.
Mr Revhead wrote:yeah.. if you have to ask.... you probably cant do it
or in bold at the top of this forum!
RedMist wrote:Low_Aa63 wrote:cool cheers for that.. its for a 3sgte rwd into a st183, i was allready planning on using the subframe from an st185 just querying(sp) the tunnel thing.
Are you taking the piss? Your attempting to create a ST185 from an ST183 with only 2WD? Your going to spend twice the value of a ST185 in fabrication costs alone.
Why not buy an ST185 lock the center diff and remove the front drive shafts? Complete at about 1/5th the cost.
