Gearbox 4 4k?
Gearbox 4 4k?
Postby DXROLLA » Fri Dec 16, 2005 6:43 pm
Hey just wondering whats the best 5spd gearbox 2 get 4 the 4k and what do they come out of, also same with diff im wanting a lsd that bolts strait in or with minimal effort.
DXROLLA
Postby Dell'Orto » Fri Dec 16, 2005 7:08 pm
The best gearbox would be a K50, unless you're making some huge power (comparatively :lol:) then you could get a T50.
Diff, it kinda depends on vehicle.
Postby DXROLLA » Fri Dec 16, 2005 7:35 pm
I herd you can use the diff out of coronas i thnk r they lsd?
DXROLLA
Postby Low_Aa63 » Fri Dec 16, 2005 7:43 pm
corona is a pretty rough generilsation. you have to be more specific around here.. you may possibly be wanting a t series rear or even an s series rear that would be an acceptable upgrade for a standard rolla.
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby Dell'Orto » Fri Dec 16, 2005 7:50 pm
Exactly, are you talking about a KEx or KPx chassis here?
Postby DXROLLA » Fri Dec 16, 2005 7:58 pm
Its a 1982 ke70 sedan just finished moding the 4k so wanting a lsd and 5spd box but not sure what to get.
Also i went to the clasic car racing at ruapuna the other wekend and sore a starlet with the cooling fan on radiater on the outside instead of in the engine bay side is there any advantage in doing this or is it just a space thing?
DXROLLA
Postby Dell'Orto » Fri Dec 16, 2005 8:00 pm
A K50 will be sweet provided you dont slam shift and do standstills all the time
Postby DXROLLA » Fri Dec 16, 2005 8:12 pm
Kewl and are these just a strait bolt on to the 4k? do you have to change drive shafts or nething from the k40 gearbox i think mine is
DXROLLA
Postby Dell'Orto » Fri Dec 16, 2005 8:15 pm
Yep, goes right in.
Postby Low_Aa63 » Fri Dec 16, 2005 8:18 pm
good luck finding a u series lsd
The list so far
Low_Aa63
Postby Low_Aa63 » Fri Dec 16, 2005 8:20 pm
oh and kp's run thermo switches for there radiator fans its less drag on the motor instead of trying to spin a fan with the water pump run it off a battery, and if its on the other side it makes no difference it just means its blowing instead of sucking.
The list so far
Low_Aa63
Postby Dunny » Fri Dec 16, 2005 8:21 pm
U code LSD's are around - just gotta keep an eye out 8)
Dunny
Postby Low_Aa63 » Fri Dec 16, 2005 8:23 pm
a u series lsd would most probably be worth more than your eye! they only came out in kp turbo's or sumthing....
The list so far
Low_Aa63
Postby Dunny » Fri Dec 16, 2005 8:28 pm
Not true - I own 2 of them and 1 is brand spanking new still in the box, the other is in my race car. I have a mate who also owns 2 of them and has another one for parts.
KP's never came out turbo factory so not sure where you are getting your facts from.
TRD made a U & X code LSD back in the 80's and 90's, when they used to have a starlet race series in Japan.
Like I said they are still around if you know where to look. As for price, I paid $650 for my brand new one.
Dunny
Postby Low_Aa63 » Fri Dec 16, 2005 8:31 pm
yes but factory fittments is what i wanna know.. and there was a factory turbo kp bugeye 4kte.
edited:spose i should mention it was some race motor production thing like the 4tgte.. so many released yada yada yada
The list so far
Low_Aa63
Postby fangsport » Fri Dec 16, 2005 9:26 pm
Low_Aa63 wrote:yes but factory fittments is what i wanna know.. and there was a factory turbo kp bugeye 4kte.
pictures and factory spec sheet or it didn't happen :wink:
fangsport
Postby wde_bdy » Sun Dec 18, 2005 8:46 am
Damn, you must be really really well informed on Starlets.
Or just believe every scrap of bullshit someone tells you.
:roll:
wde_bdy
Postby Mr Revhead » Sun Dec 18, 2005 1:07 pm
you are probably thinking of some race car.
there was NEVER a kp series starlet turbo made and sold by toyota.
there were some special versions of K and T sereis engines that probably found there way into factory race cars but none of those were turbo that i can recall.
Postby Blown5k » Mon Dec 19, 2005 12:57 pm
there was NEVER a kp series starlet made and sold by toyota
oops think there`s a turbo missing out of that statement. :wink:
Supercharged 5k kp60
2005-2006 1301-1600cc Canterbury Car Club race series champion.3rd 0-2500cc.
Blown5k
Postby Mr Revhead » Mon Dec 19, 2005 1:05 pm
i have no idea what your talking about :oops: :lol:
