st165, what colour is oxy sensor wire?
Postby DFECTED » Sun Dec 18, 2005 10:29 am
there are three wires floating around that area that arent connected, its missing badly under load and no matter which wire I hook the oxy sensor to it still brings up the fault code.
I just need to know the colour of the wire the goes to the sensor
DFECTED
Postby solberg Fan » Sun Dec 18, 2005 1:04 pm
how many wires does the oxygen sensor have?
If its one wire it will probbly be black. Two wire is black and white and three wire is black with two white wires.
Missing under load could also be a lead.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby vvega » Sun Dec 18, 2005 1:08 pm
its not black :D
its white at the ecu end so it will be eathier white off white or a browny color at the sensor end
the color changes from the heat :D
v
vvega
Postby Skidman » Sun Dec 18, 2005 2:48 pm
the oxy sensor is a single black wire, with a yellow plug, after the plug it turns into a ?? color wire with a heat resistant sheeth over it.
Just a prime example of somebody who dosnt have a clue what they are talking about.
IT IS BLACK.
Hondas are made for people who dont know better.
Skidman
Postby vvega » Sun Dec 18, 2005 4:24 pm
sorry mate i have a gt4
and unfortunatly for you have just installed a a/f guage on that very wire not more than a week ago
http://www.gtfours.co.uk/what/ecu_pinout/165/ecu_pinout.htm
i think you need a new soruce of info :D
v[/url]
vvega
Postby vvega » Sun Dec 18, 2005 4:26 pm
Skidman wrote:the oxy sensor is a single black wire, with a yellow plug, after the plug it turns into a ?? color wire with a heat resistant sheeth over it.
IT IS BLACK.
attually here let me help you
Skidman wrote:the oxy sensor is a single black wire, with a yellow plug, after the plug it turns into a whitecolor wire with a heat resistant sheeth over it.
IT IS BLACK.
he knows what the oxy wire is
he wants to know what the loom color wire that hooks up to it is
you should be sure you understand whats been asked before you flame people
v
vvega
Postby Skidman » Sun Dec 18, 2005 7:31 pm
Yep na fair enough im not a mind reader.
I only answered the question asked.
Little bit of pot calling the kettle black here though, aye matey?.
Skidman
Re: st165, what colour is oxy sensor wire?
Postby Skidman » Sun Dec 18, 2005 7:49 pm
DFECTED wrote:there are three wires floating around that area that arent connected, its missing badly under load and no matter which wire I hook the oxy sensor to it still brings up the fault code.
From this I gather that he wants the "colour of the wire the goes to the sensor" - which is black in my car anyway (from the loom side). On the sensor side is irrelavant, unless the factory wire has been cut. In which case it dosnt matter anyway. If it did matter the wire from the plug to the sensor is not color coded as such as it has a heat proof rubber based cover which is tightly wrapped with a heat resistant sheeth, which is again covered with a loose heat resitatant cover.
Dont have a clue about what you are talking about here "and unfortunatly for you have just installed a a/f guage on that very wire not more than a week ago" I dont even have an A/F gague.
Please before you go round thinking that you are the man take a chill pill and realize that there are always people who make $&#$% ups and you might be one of them.
NO more B/S please.
Skidman
Postby vvega » Sun Dec 18, 2005 9:00 pm
Skidman wrote:Yep na fair enough im not a mind reader.
i gave you a link to a ecu pinout and wire color code
Code: Select all
IT IS BLACK.
i have to say ans this is what i didnt understand
why would he ask for the wire color off the sensor
i mean it is attached to it
he goes on to say he has bare wire
so im guessing they are no longer covered
mistakes i have no issue with everone makes them
but then attacking the guy thats tring to help with the right info..... well
that s what pisses me off
its nothing personal
and i hope to meet you at one of our hamilton meets
v
vvega
Postby Skidman » Sun Dec 18, 2005 9:20 pm
K, sorted.
The ECU pin out wire colour is White.
The Engine bay wire colour in my 1987 GT celica is black.
Either the wire changes colour somewhere, or toyota made a wire colour change somewhere.
Sorry that I took it personally, the reason for that was you burnt me on another post for no apparent reason. Hope that this dosnt continue. When is the next Ham meet, ive never been to one, and havnt a clue what they are about please let me know.
Skidman
Postby vvega » Sun Dec 18, 2005 9:27 pm
sorry im moody at the best of times
have a look down at the hamilton section for the details
or feel free to pop over to te awamutu for a visit
might tri to organise a boxing day bbq for us
v
vvega
Postby Adydas » Sun Dec 18, 2005 11:10 pm
im there Waynester :P
Adydas
Postby vvega » Mon Dec 19, 2005 6:34 am
Adydas wrote:im there Waynester :P
wicked cliffy
ok well i guess ill post somehitng up and get the wheels in motion
v
vvega
Postby DFECTED » Tue Dec 20, 2005 10:09 pm
Thanks for all the info, I found the sheilded wire and I dont know what colour is used to be but now its brown. I connected it to the O2 sensor and changed the leads.
I now see 14psi on the boost gauge, the most I have ever seen, it normally cuts/ misses at 5psi. The only difference is it now cuts/ misses at 14psi, is this boost/ fuel cut im hitting?
I now only get fault code 11
and when not in diagnostic mode the engine check light stays on
DFECTED
Postby vvega » Tue Dec 20, 2005 10:13 pm
number 11 is momentary los of power to teh ecu
and 14 psi will be boost cut
but thats normmally like a proper cut not a splutter
give us a few more details please i will do my best to help ya
v
vvega
Postby vvega » Tue Dec 20, 2005 10:24 pm
vvega wrote:its not black :D
v
brown sounds good :D
vvega
