ollieboy wrote:We had this question in a physics exam and the whole class apart from me and another guy got it wrong, the people who got it wrong still didn't grasp the concept after over an hour of explaining.
vvega wrote:i ask you this
if the planes wheels are so important to taking off
how dose a harrier do it
how do other VTAL aircraft do it
v
snwtoy wrote:ollieboy wrote:According to the New Zealand institute of Physics Test Paper. The Plane would not take off because of the fact there is no air movement over the wings.
It is true that planes take off on skis etc but they are still moving when they take off, they are being thrust by props or jets which push the plane along and cause air movement under the wings which creates lift.
If the plane on the conveyor belt was moving at huge speeds it still remains in the same position in terms of displacement relative to the earth beneath the conveyor belt. This means there is no air movement across the wings to create lift.
I want a link to this test you harp on about.
The plane engines create thrust agains the surrounding air, generating air speed and thus lift as the pressure difference above and below the wing increases.
To say that the plane never takes off is just wrong. It doesn't matter if the ground is a conveyor belt, an oil slick or a runway - so long as there is a friction reducer involved the plane will take off.
vvega wrote:interesting
i guess they $&#$% that one up aye
you didnt go to cambrige high school did you ??
v
fivebob wrote:Imagine a plane is sat on the beginning of a massive conveyor belt/travelator type arrangement, as wide and as long as a runway, and intends to take off. The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation.
There is no wind.
Can the plane take off?
Explain why it can, or cannot, take off?
This is why on Battleships they use a tow method to launch aircraft otherwise it would be a lot simpler to use a travelator design if it were physically possible.
method wrote:This is why on Battleships they use a tow method to launch aircraft otherwise it would be a lot simpler to use a travelator design if it were physically possible.
What the heck? You have to be kidding?
A steam powered catapault is probably the easiest thing you could make.
And the travelator wouldnt hold a aircraft stationary so it wouldnt work. The travelator changes the GROUND SPEED not the AIR SPEED.
The travelator wouldnt stop the plane from moving fowards at all, the plane pushes air to move so it will go forards regardless of what the ground underneeth it does.
Why do you think a plane has wheels? The idea of the wheels are to provide as little friction between the plane and the ground.
So if the plane accelarated fowards at 10kph, the conveyor backwards at 10kph the planes ground speed would be 0kph relative to the conveyor but 10kph relative to the air. It would also be 10kph relative to the true ground speed hence moving fowards.
Ollieboy you obviosuly have no knowlage in this field, all you are doing is using your intuition. Trust me once you start studying dynamics you will quickly realise how wrong your intuition can be. Go study dynamics at university and you may have a better idea of it all, level 3 phsycis is arse, all you learn is the basics of statics (equilibrium and the likes) and a very tiny bit of dynamics, hardly anything at all.
eg. if the plane is MOVING FOWARDS relative to the ground at 5kph, then the travelator is going to be moving backwards at 5kph.... meaning that the speed of the wheels spinning is 10kph. The plane is still moving fowards (relative to the ground, and the surrounding air) at 5kph though.....
ollieboy wrote:So here I am swallowing my pride. I am sorry for what I said earlier but I believe the plane will take off.
