MrOizo wrote:Brick wrote:argueing on the internet is like the special olympics, even if you win your still a retard![]()
its not really arguing, its more of a debate
MrOizo wrote:no_8wire wrote:MrOizo wrote:if there was no friction in the wheels then the plane should sit there at 0 km/h ground speed. the plane could then accelerate up to take off speed.
i guess this question depends what variables you want to include.
yes it could accelerate its take off speed. however it still wouldnt be moving and therefore not creating any lift force/ real air speed...therefore its supposed "takeoff" speed would be non exsistant...
no no no... the ground speed and air speed would both be 0.
it then accelerates to lift off velocity. and walla... take off![]()
and what ever take off velocity was, double that and thats the velovity of the surface of the wheels of the aircraft.
ollieboy wrote:geishaboy wrote:I can't believe I waded through three pages of this sh*t
There is only one *one* 1 way to know for sure
And that is a pratical experiment
I'm keen if you are
Im keen as well
no_8wire wrote:MrOizo wrote:no_8wire wrote:MrOizo wrote:if there was no friction in the wheels then the plane should sit there at 0 km/h ground speed. the plane could then accelerate up to take off speed.
Its lift off velocity is depedant on the amount of air/speed of air under wings.
If the plane is not moving as its velocity on the belt is "0" effectivly( speed plane-speed belt = 0).
There is no way therefore that the plane could reach a speed to take off, as no matter what speed it was it still wouldnt be moving, and there would be no air movement to creat lift.
ollieboy wrote:no_8wire wrote:MrOizo wrote:no_8wire wrote:MrOizo wrote:if there was no friction in the wheels then the plane should sit there at 0 km/h ground speed. the plane could then accelerate up to take off speed.
I dont want to sound like a penis but just to correct that the lift is dependant on the air above the wings believe it or not.
ollieboy wrote:no_8wire wrote:YAH some one UNDERSTANDS!!!!!!!!!!
come one, thats what I was trying to say ages ago.
no_8wire wrote:ollieboy wrote:ollieboy wrote:no_8wire wrote:YAH some one UNDERSTANDS!!!!!!!!!!
come on, thats what I was trying to say ages ago.
okay then WE understand! ( OB, N8, V8 )
