5k starving!
5k starving!
Postby ke_25 » Mon Dec 19, 2005 5:52 pm
5K starving for gas!
drivnig the other day and it statred to surge when put foot flat t teh floor, then 20 mins later the car died, and wouldnt start, let settle for a bit and managed to jst make it home, joting up hill. Cleaned out the carb last nite and went for a drive and it seemd ok for about 3 minutes, the the same thing occured. The bowl in the carb doesnt seem to be filling up all teh way as when pump teh punmp on teh carb, only last for about 3 squirts then empty.
Tried pumping fuel into a botle to see if fuel pump was pumping and it seemd to be ok, but not the higest pressure.
and ideas what this could be?
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby solberg Fan » Mon Dec 19, 2005 6:38 pm
Maybe the float level set up wrong?? Im not sure on your set up, but my carb has a small inline filter at the banjo.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby SUBARUCONVERT » Mon Dec 19, 2005 7:42 pm
could be the needle valve sticking if the bowl isnt filling
SUBARUCONVERT
Postby fangsport » Mon Dec 19, 2005 9:00 pm
modified engine with a standard mechanical pump??
fangsport
Postby Virtual Genocide » Tue Dec 20, 2005 8:18 pm
fangsport wrote:modified engine with a standard mechanical pump??
I doubt thats the problem unless its really old and worn out.
You'd need to be making BIG HP to need an upgraded fuel pump.
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby Skidman » Tue Dec 20, 2005 9:47 pm
Yea, carb pumps only run like 4 psi max usually.
I'd go with "solberg Fan" on this one, while the carb is appart to check the level make sure that the needle isnt sticking like "SUBARUCONVERT" suggested. Plus make sure when you pull the float out that its not got a hole in it or somthing like that and filled with fuel.
Hondas are made for people who dont know better.
Skidman
Postby ke_25 » Wed Dec 21, 2005 4:47 pm
yer filter had crapd itself and then the small fine filter before the needle valve was blocked up, cheers
ke_25
Users browsing this forum: Bing [Bot] and 31 guests
