hehe, I could just imagine it.
"but the plane isnt moving!" *SMACK*
"Wheres the force of the thrusters going then?!" *SMACK*
riddles wrote:Everyone seems to agree that the engines provide thrust, what appears to be the argument is does the conveyor provide reverse thrust (drag) ie the plane is moving forward because of thrust at 100Kph, the canveyor backwards at 100Kph and the wheels are turning at 200Kph, The engines cease to thrust, will the plane still continue forwards?
RomanV wrote:You know how you drive past a horrible car crash, and cant help but look?
Well this thread is like driving past a horse crash, where you cant help but get out of the car and go flog the sh*t out of all of the dead horses lying around.
Razz wrote:Push matchbox car on treadmill against the motion of the belf. Can you push the car from one end to the other?
like above, it would move forward, and that is because your normal treadmill moves at a constant speed. It makes no odds whether the car is pushed very quickly or with a huge amount of thrust.
For something to move forward it must gain traction or be moving faster than the surface below. In the case of the plane, its forward speed is transfered through its wheels.
Imagine a plane is sat on the beginning of a massive conveyor belt/travelator type arrangement, as wide and as long as a runway, and intends to take off. The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation.
There is no wind.
Can the plane take off?
Explain why it can, or cannot, take off?
MrOizo wrote:Imagine a plane is sat on the beginning of a massive conveyor belt/travelator type arrangement, as wide and as long as a runway, and intends to take off. The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation.
There is no wind.
After reading it again i still go with Yes.
I see the plane taking off as normal other than the wheels spinning twice as fast as they should.
Question is saying that the conveyor is making only the WHEELS go faster in the opposite directioin to the planes movement.
What if the belt was to go the same way as the plane? still wouldnt make any difference.
V8MOFO wrote:I think we can all agree now that the plane can move forward relative to the ground.
Razz wrote:V8MOFO wrote:I think we can all agree now that the plane can move forward relative to the ground.
No I do not agree at all, the plane is simply not moving.
Razz wrote:the belt is counteracting foward movement or acceleration
ollieboy wrote:We had this question in a physics exam and the whole class apart from me and another guy got it wrong, the people who got it wrong still didn't grasp the concept after over an hour of explaining.
fivebob wrote: The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation.
matt dunn wrote:fivebob wrote: The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation.
So,
The plane moves forward at say 10kmh, the bottom of the wheel moves towards the back of the plane and the top of the wheel moves to the front as the wheel is rotating.
The convey moves in the opposite direction to the part that contacts it.
so the conveyer moves forward in the same direction as the plane.
The plane moves forward, the conveyor moves forward, and.....
THE WHEELS DO NOT TURN AT ALL,
no matter how fast the plane moves.
