bye bye sunroof?
bye bye sunroof?
Postby Santa'sBoostinSleigh » Wed Dec 21, 2005 11:14 am
can anyone tell me if theres any major hassles in removing (ie pannelling over) a sunroof?
(either legally/safety/mechanically)?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
nah its sweet
Postby shaggz » Thu Dec 22, 2005 11:57 am
bit of cardboard i can provide boxes, and chicken mesh, then a bit of lick and stick and your set hahahahaha ask bj meuli panel beating they good prices
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby Malcolm » Thu Dec 22, 2005 12:02 pm
I reckon you should make a fibreglass replacement panel :)
you could even make it removable so you could have all the weight savings of not having the sunroof, but the wicked-ness of an open roof in summer :)
Postby Santa'sBoostinSleigh » Thu Dec 22, 2005 1:50 pm
All_Fours wrote:I reckon you should make a fibreglass replacement panel :)
so the water leaks in during winter? :P
its for the racecar
however i have heard that welding a roof can be damn ugly/expensive/time consuming....
Santa's Mega Sale
Postby Malcolm » Thu Dec 22, 2005 2:15 pm
welding it in will almost certainly cause the roof to buckle
I briefly owned a *shudder* ma61 race car (i only bought it for parts, promise), and it had a steel panel rivetted in place of the sunroof
anyway if it's for a racecar, I'd just go fibreglass or steel, but don't weld it in, just fix it with fibreglass
Postby Santa'sBoostinSleigh » Thu Dec 22, 2005 2:18 pm
so you rekon just cut all the roof crap out, apply heaps of sealer and heaps of pop rivets?>
Santa's Mega Sale
Postby Malcolm » Thu Dec 22, 2005 3:02 pm
nonono
remove the entire sunroof assembly, then make a panel, to fill the gap, and secure it in place by fibreglassing around the edges
you could try welding a panel in, and just do lots of spot welds, taking your time to make sure you don't heat it too much to cause buckling.
If it was me, I would fibreglass it in, mostly because fibreglassing is something I know I could do without $&#$% it, but welding might cause problems
Postby Mr Revhead » Thu Dec 22, 2005 3:08 pm
i think you will find there are rules for doing that for a race car.....
its been a while but i recall having this discussion before and its not as easy as just filling the hole....
check with MSNZ (or leon) doesnt cost to ask, but can cost to fix a f**k up
Postby Leon » Thu Dec 22, 2005 3:25 pm
Mr Revhead wrote:i think you will find there are rules for doing that for a race car.....
Heh ... he has already done exactly that :)
Nope, MSNZ rules barely mention sun roof's at all.
Do pretty much whatever the hell you like, so long as you present a neatly finished job without sharp eddes. I've seen all sorts of wierd and wonderful creations, none of which were dangerous. The strength in the roof becomes essentially irrelevant once you put a cage in the car.
Postby Mr Revhead » Thu Dec 22, 2005 3:36 pm
oh ok then
well, good thing you asked then :D
Postby 2LTR Rona » Thu Dec 22, 2005 3:37 pm
Santa'sBoostinSleigh wrote:so you rekon just cut all the roof crap out, apply heaps of sealer and heaps of pop rivets?>
That would be one cheap, easy and nasty fix :P I'd be more inclinedto look at the fibreglass option if you can, much nicer finish 8)
2002 Altezza, 1974 KE25
2LTR Rona
Postby Santa'sBoostinSleigh » Thu Dec 22, 2005 3:39 pm
for the fibreglass route, id be concerned about cracking, and the associated leaking
im guessing tack/spot welding would also leave gaps and hence leak like a sieve
i can just 'steal' some of the roof from my wreck and slap that on top, or use an ali panel
including an arse load of sealer and 100's and 100's of rivets!
Santa's Mega Sale
Postby Bling » Thu Dec 22, 2005 4:16 pm
Santa'sBoostinSleigh wrote: or use an ali panel
I like this idea :lol: :lol: :lol: rugged az au 8)
Postby flygt4 » Thu Dec 22, 2005 5:05 pm
ive seen sumthing on tv once where they attempted to weld a roof :? was a very bad idea , they heated it too much and it buckled and flexed uber bad.
flygt4
Postby DRFTIN » Thu Dec 22, 2005 5:33 pm
dad chopped up a roof that had no sunroof to begin with, cut out a piece the shape he needed, and used some kind of sealant/glue stuff to stick it in :?
worked pretty well but looks a bit rangi
good thing the new car has no sun roof and all the other light weight parts :D
DRFTIN
Postby 2LTR Rona » Thu Dec 22, 2005 5:37 pm
flygt4 wrote:ive seen sumthing on tv once where they attempted to weld a roof :? was a very bad idea , they heated it too much and it buckled and flexed uber bad.
mmm that was on monster garage I think (if its the same one, I'm thinking off) took another guy ages to fix that flock up :twisted:
Do not weld your roof :P
2LTR Rona
Postby GOLDAE86 » Thu Dec 22, 2005 6:17 pm
A mate of mine removed the sun roof and had sheet metal spot welded on the inside and then some how made it look like it didn't ever have one.
Wat kind of car is it :D
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby deaf_rattle » Thu Dec 22, 2005 6:21 pm
All_Fours wrote:welding it in will almost certainly cause the roof to buckle
nothing wrong with ma61s, but that was a pretty shoddy example you had
Postby neo » Thu Dec 22, 2005 11:19 pm
if your really serious, remove all the mecahnisms (8 bolts in my account) cut off all the extra metal tags. Spot weld in a metal sheet below the normal roof line, use urthane sealant around the inner edges, then fibreglass (with matt) the hole and bog to smooth it all off..
Many many hours of work.
Or go the easy route, cut off the rear half of the slider for it, and install the cage around the sun roof .. YEY
neo
Postby KinLoud » Fri Dec 23, 2005 3:42 pm
Why do you want to remove the sunroof?
- weight
- looks (sunroof a bit odd in a race car?)
- rollcage fitment
If you're not going to cage it straight away, keep the sunroof while you work through the options.
Yeah - what type of car did you end up with?
Ken
Ham
021 408 863
