how much harder does a stock 4age blacktop go than a bluetop
Postby escortman » Thu Dec 22, 2005 6:38 pm
lookin at buyin a ae82 that has a 20v blacktop in it how much hard wud it go compared to my current ae82 with bluetop in it , also cuz the 20v has vvt instead of tvis can i get one of them vtec controllers
escortman
Postby Mr Revhead » Thu Dec 22, 2005 6:51 pm
harder than ron jeremy
and no to the vtec controller
Postby escortman » Thu Dec 22, 2005 6:56 pm
ok lol
um cuz isnt vvt same as vtec and i spose if u say , u know ur shit
escortman
Postby Mr Revhead » Thu Dec 22, 2005 7:00 pm
no its quite different.
and it kicks in quite low too..... fitting something like a vtec contorller will make it run worse. leave it stock, or fit a good ecu and go playing on a dyno 8)
Postby escortman » Thu Dec 22, 2005 7:03 pm
some guy sed it kicks in at 5600
escortman
Postby mycoolcar » Thu Dec 22, 2005 7:58 pm
escortman wrote:some guy sed it kicks in at 5600
Yes, some guy is always an extremely reliable source for all you need to know about cars.
mycoolcar
Postby escortman » Thu Dec 22, 2005 8:30 pm
i actually know a bit about cars, but as the vvt system is differnt to tvis im not to sure when it kicks in and the guy is actually some1 hu owns a blacktop levin so i assumed he knew wat he was talkin about, but bcuz mr revhead sed it comes on quite early im not sure as i feel teh tvis system would be better if it came in at 3 instead of at 4500
escortman
Postby Mr Revhead » Thu Dec 22, 2005 9:03 pm
tvis is very differnt from vvt. so relateing how they behave to the other isnt accurate.
im sure of the exact change points on the blacktop, but on the silvertop once its abotu 1/4 warm it comes on at anything over a 1/4 throttle. its not rev dependant. thats why a vtec contoller would make it worse... as it would just switch at a set point, not the best place as the ecus sensor determine.
so unless youv got a flash ecu and can take the time to experiment with the settings its best just to leave it
Postby Emperor » Thu Dec 22, 2005 9:09 pm
I think its different in every car.. For the Skyline it's weird(VVL).
First gear, it kicks around 4,000rpm you feel it rush, but 2nd gear you dont feel it at all.
Emperor
Postby escortman » Thu Dec 22, 2005 9:40 pm
yeh i know there differnt tvis is to do with butterflies in the itake manifold, isnt vvt cams ? lik mivec vtec etc
escortman
Postby frost » Thu Dec 22, 2005 10:43 pm
yes its cams but not what some people think it is!
v-tec is a 16 valve engine and always will be. vtec kicks in at a set rpm only!!. the intake cam looks alot like a 4age 20valve cam as both have the same amount of lobes 12 of them. so its 3 lobes per pot(-2 exaust) . however when vtec is off it uses the outer two like any normal 16valve engine. but when vtec is on it switches to the middle crazy lobe(higher lift and duration) so its like having three cam shafts in your engine.
blacktop VVT is nothing like vtec, its more to do with cam timing then anything else. it advances/retards(matt daimon) the cam timing. they are 20 valve engines so have more lobes but always uses them all.
vvt comes onto play only when the engine feels like it :cry: right temp. throttle position, ect ect..
mivec (shrug shrug) i have no idea what the hell is going on in there :roll: not really into them :lol:
Postby escortman » Thu Dec 22, 2005 10:46 pm
im going to do a searcg on vvt now i sota understand
escortman
Postby frost » Thu Dec 22, 2005 10:53 pm
opps for got to answer yor first question.yeah they are really good engines(waiting for the bash) take it for a spin and let the thing rev as high as it wants to go. they love to be taken very high and keep asking for more. they make about 145hp stock so its more then bluetop(stock). no to the vtec controler. say yes to safc2 is great for tuning. have fun
Postby escortman » Thu Dec 22, 2005 11:22 pm
wat wud b some good basic mods to start of with be? 2 1/2 or 2 1/2 in echaust pod , airbox and cold air intake and port n polish
escortman
Postby barryogen » Fri Dec 23, 2005 8:40 am
frost wrote:blacktop VVT is nothing like vtec, its more to do with cam timing then anything else. it advances/retards(matt daimon) the cam timing.
nice :)
barryogen
2ZZ Guru in training
Postby JT » Fri Dec 23, 2005 10:52 am
Bluetops make ~80-85kws at the wheels
Blacktops make ~95-100kw at the wheels
Can you take the blacktop one for a drive? That would be an easy way to see if the difference is worth your money.
JT
Postby Distrb » Fri Dec 23, 2005 11:03 am
I had a bluetop in my car...
Then i swapped it for a blacktop in the same car...
Both are standard, Blacktop goes ....
Mr Revhead wrote:harder than ron jeremy
Bluetop does not..
Dont p1ss with the vvt either, unless you're removing it completely to get some super agressive cams and adjustable cam wheels
Distrb
Regular Poster
Postby Lanius » Fri Dec 23, 2005 2:42 pm
I've got an AE82 with a blacktop. You will never, ever regret buying that car :)
I sent someone on here a video of the AE82 vs a Honda Civic SiR ... not sure if he'll read this post or not, but if he does, I'm sure he'll tell ya what they can do.
Lanius
