Also gear changes help alot too! In a 20v you should be changing just befor redline and you may be able to hold it in 3rd over the line depending on the launch which means 1 less gear change and a quicker time
B1NZ wrote:yeah, try about 20psi in the front tyres, and 40psi in the rears might help a tiny bit.
I found in my 20v sometimes i could make it across the line in 3rd depending on the launch
