Fuel/Ignition Problems.....
Postby MINTFX » Sat Dec 24, 2005 9:05 pm
Well... I was heading off to play a round of golf this arvo. Got half way there and noticed the power was coming in and out really weirdly. I pulled over, popped then bonnet and had a look as you do... Nothing wrong I could see, revved it a bit and it seemed fine. Turned around and headed home and it was still doing. Unfortunatly I live on a hill... I got to the bottom and it started to get power then lose power really bad so I stopped and started off again, giving it plenty of gas and dropped the clutch otherwise it stalled. I only had a new clutch put in about 6mnths ago, so unless its faulty I dont see why it would be the clutch... But it seems like it is. Can anyone comment on this?
MINTFX
Postby AJz » Sat Dec 24, 2005 9:49 pm
that doesnt sound like anything to do with your clutch or your gearbox.
have you played with or installed anything recently?
I had vtax :(
AJz
Postby CozmoNz » Sat Dec 24, 2005 9:49 pm
could be anything, your timing throwing a hissy... i dont know why your blaming gearbox....
my guess is maybe your dizzy cap is fzored, causing a minor miss (uneven power flow).
but yeh, little bit more information would be just lovely dovely
Rayne For President!
CozmoNz
Postby mr30%jr » Sat Dec 24, 2005 9:56 pm
try putting some gass in it :lol:
might be your clutch
mr30%jr
Postby tomo1985 » Sun Dec 25, 2005 12:03 am
You may have dirt in the petch tank, when you drive it mixes it up maybe????
tomo1985
Postby AJz » Sun Dec 25, 2005 1:28 am
clutch has nothing to do with it, IF your clutch was fukzOrd then it would just slip (eventually being undriveable) but you wouldnt stall, you would just rev but go nowhere.
as coz said, sounds like ignition or whatnot which is why i asked if youd been playing/fitting/fixing something recently.
I had vtax :(
AJz
Postby MINTFX » Sun Dec 25, 2005 11:12 am
Yea I did root the clutch 6mnths ago thats why I got a new one, only just made it into the shop. The only reason I thought it was the gearbox is because it was fine when I pulled over and check the engine out, it revved fine and ran sweet. I guess it mustve been some dirt and shit in the petrol, i tried to started it up this morning but it seemed to be being starved of enough petrol and just died. Finally got it idling and i took it for a drive, gave it a good blowout and it seems to be fine, Mustve been the shitty petrol. Cheers for the comments. And no I havent been fidling with anything recently.
MINTFX
Postby CozmoNz » Sun Dec 25, 2005 11:30 am
When was the fuel filter last changed?
CozmoNz
Postby MINTFX » Sun Dec 25, 2005 11:32 am
Wouldnt have a clue. Will do it in the new years. My dads a mechanic so ill leave it with him. Selling it soon so I want to keep it running perfectly.
MINTFX
Postby MINTFX » Fri Dec 30, 2005 6:14 pm
Just an update. Replaced the fuel filter. Took a bit to get started, it would start, stay at 1000rpm then die, after a few times itd get going. Got it going this morning and filled up (Scored a free full tank of gas). Got home again, everything was sweet. Got it started after a few tries to go to my mates place got there alright, started driving home, half way down his hill it just died. So we ended up towing it back to my place. (Cheers to Speedster Chick for sitting up my arse for some of the way :roll: ) Going to have to organise an auto elec to come up and check it out. It is sparking fine as I did a quick test with a screwdriver.
MINTFX
Postby ChaosAD » Fri Dec 30, 2005 7:15 pm
Mine would do a simmilar thing cos it had either a $&#$% oxy sensor or map sensor. Check for any fault codes.
Or have u filled up at any shitty backroad petrol stations?
ChaosAD
Postby MINTFX » Fri Dec 30, 2005 7:21 pm
Nope just main shell/bp stations. It just wont start AT ALL now. It still cranks over but just wont fire :( Sucks as I just got my custom speaker pods made up (Huge ups to DeeCee).
MINTFX
Postby Mr Revhead » Fri Dec 30, 2005 7:39 pm
as above check the codes
Postby MINTFX » Fri Dec 30, 2005 7:44 pm
Where and how do I check the codes? (Have no idea) I have the haynes book but it hasnt got much stuff on the FXGT.
MINTFX
Postby Mr Revhead » Fri Dec 30, 2005 7:47 pm
Postby MINTFX » Fri Dec 30, 2005 8:05 pm
Ok cool thanks man. (Hopefully I dont go shorting something out)
EDIT! The car doesnt start? Is it still worth doing it?
And.. I cant find the blimin thing?
MINTFX
Postby no_8wire » Fri Dec 30, 2005 8:28 pm
INFO wrote:In your engine bay you will have a small Diagnostic box.
Get a little wire and bridge E1 and TE1 terminals.
Turn the car to 'ON' - Meaning don't start it.
Look at the engine check light and count the flashes and write the numbers down. Each number will mean something different.
Flashes will be as follows:
1 1 1 1........1 1 1 1 1 wich will mean Code: 45
You can check what the codes mean on this Site:
http://www.cygnusx1.net/supra/techtip/engineerrorcodes.html
Doesnt matter if not start to check...
no_8wire
Postby MINTFX » Fri Dec 30, 2005 8:29 pm
Ohhh sh!t, Maybe i should leave it till tomorow I am really tired. I cant find the little black box either? Any pointers as to where itll be. (Already had a good hunt around the battery area.
MINTFX
Postby Alex B » Fri Dec 30, 2005 8:32 pm
Get the fuel pressure checked out.
Postby MINTFX » Fri Dec 30, 2005 8:44 pm
pyro_sniper2002 wrote:Get the fuel pressure checked out.
Yea, My dad is a mechanic and ive been talking to him about it and he siad he thinks its something to do with the fuel pump or the wiring to it. Hes away at the moment and I need the car going asap.
MINTFX
