ST165 Stuck at 0.5Bar
Postby sergei » Fri Dec 23, 2005 10:49 pm
my ST165 is stuck at 0.5bar boost, is there any reason for Turbo VSV not opening? Turbo VSV has been relocated (now sits next to intercooler)... Intercooler (st205 unit) is full of coolant, have not got any error codes, and it was working before I was getting 0.7bar...
Postby Malcolm » Fri Dec 23, 2005 11:56 pm
might just be broken?
have you tried disconnecting it from the ECU and earthing the wire that goes to the ECU, to see if it opens then?
Postby sergei » Sat Dec 24, 2005 1:58 am
I've tried to apply 12v to it while blowing air thru it, it works... possible ECU does not supply signal to it... anyway, I've made an ovveride switch wich turns it on aswell as water pump and fan on i/c radiator...
Postby Adydas » Sat Dec 24, 2005 12:04 pm
have you jumped that bodgy pin that used to be in the old WTA IC?? as if that senses to hot it limits the VSV dont it? so if its flapping around or unplugged that might be your answer.
Adydas
Postby sergei » Sat Dec 24, 2005 7:42 pm
I've driven with the ovveriden VSV and still it does not boost above 0.5bar, I think maybe T connector is too restrictive to work porperly or turbo housing arround wastegate is cracked...
Postby sergei » Mon Dec 26, 2005 11:07 am
I found the problem: when I relocated TVSV I T into hose between snail and wastegate acutator, this does not work for some reason, when I used second port on wastegate (which I blocked in the beginning) and removed T line it strated to boost 0.6Bar...
BTW drilling the ports on the TVSV will not lead to higher boost (i did try different sizes till 5mm)...
Postby Malcolm » Mon Dec 26, 2005 3:50 pm
supposedly you need to drill to 6.5mm to get something like 12psi. It should work, because it's an air bleed device and the bigger the hole, the more air it will bleed
Postby sergei » Mon Dec 26, 2005 5:29 pm
I'll try 5.5 to get 10-11psi I'm after, the thing is that the internal diameter of the valve stays the same...
Postby Adydas » Mon Dec 26, 2005 5:52 pm
im not fully understanding this.. But wouldnt it be easyer to totaly remove this unit and replace with a aftermarket boost controller?
Adydas
Postby sergei » Tue Dec 27, 2005 4:23 am
proper electronic one is too expensive... mechanical valve ... I'll be better off with stock redrilled (atleast I get the switch)...
Postby Adydas » Tue Dec 27, 2005 1:09 pm
expensive yeah i agree, but i think my ones great. Second hand for $500.
Adydas
Postby vvega » Tue Dec 27, 2005 1:19 pm
better off to get a second hand link for that price for the 165
that way you get over teh stupid fuel cut
v
vvega
Postby mr30%jr » Tue Dec 27, 2005 2:38 pm
well its not going to bleed if you vsv aint opening up is it :?
you could drill a 10mm whole and still wont bleed if the vavle is shut
mr30%jr
Postby sergei » Tue Dec 27, 2005 6:01 pm
valve is not shut... I've made a switch wich ovverides the ECU, low boost 0.45Bar high boost 0.6bar..
With Link does it comes with basic tune or do I have to get it tuned somewhere?
Postby sergei » Sun Jan 01, 2006 3:40 pm
I've raised boost further to 0.7bar using 1 cable tie clamped to the hose wich is going from turbo to wastegate...
Postby solidog » Mon Jan 02, 2006 12:25 am
what a maori job! im allowed to coz im native... and I stilll wouldn't do that!
-=4age inside ~ Allmotor Toyota=-
I know stuff, im modest, I get involved
Yeah newtown ae that me! Did you know "Newtown : Its a bit shit!" but not me!
solidog
Postby sergei » Mon Jan 02, 2006 8:36 am
well I'm far from maori, but you can say russian job ;) boost from Motherland!
