Hi, will Supra CT26 turbo will bolt on instead of ST165 CT26?
Will it have any gains on high end as with ST165 CT26 it does not go very well above 5000rpms...
What Supra model had CT26 - MA70?
All_Fours wrote:there's a few guys on mr2oc.com using the supra turbo, with the supra exhaust housing, on sw20 turbos, with stock manifolds. One guy who's doing quite well with it reckons that if you put the 165 and supra exhaust housings side by side you can see the port is larger on the supra one.
The twin entry exhaust housings also fit onto the supra turbo
