Blacktop injector help - quick one
Postby Ako » Wed Dec 28, 2005 5:28 pm
Yes I did a search, no it wasn't much help and I wasted half an hour.
I need to know what config the injectors from a 97, blacktop 4AGE will be. I've established they're low impedance, side feed - but what are they interchangeable with? Funnily enough the 4AGE isn't the most common car to be cranking the fuelling on, so all my injector catalogues cover 3SGTE, 2JZ etc, not the midget engine. Just need to know so I dont go sending someone the wrong injectors by accident.
Cheers team :)
Ako
Postby Ako » Thu Dec 29, 2005 12:39 pm
Oh come on, someones got to know this?
Ako
Postby Malcolm » Thu Dec 29, 2005 12:49 pm
well I know silvertops are interchangable with 3S-GTE/2JZ side feeds, but don't know about the black tops. Probably a good chance they're the same, but I can't say for sure :)
Postby Dell'Orto » Thu Dec 29, 2005 12:49 pm
The way you've posed the question is kinda confusing...you're asking what configuration they are then answering it in the next line :?
People seem to use the Gen 2 3SGTE injectors as an upgrade for 20v turbos though.
Postby Ako » Thu Dec 29, 2005 12:52 pm
No no, I mean I know what config they are - BUT I need to know what they can be interchanged with. Just "side feed low impedance" isn't enough, some injectors need fitting collars when going to sard injectors. The silvertop, yeah no worries, but I don't know if the blacktop is any different or not, and can't find the info online myself anywhere.
Ako
Postby Mr Revhead » Thu Dec 29, 2005 1:45 pm
i would bet they are the same fitment as the silvertop ones. toyota is pretty good like that.
theres a few parts on those T/Bs that are the same.
i think the only way to comfirm is to do some bonnet lifting
not to be confused with shirt lifting
but i would be very suprised if they were different
Postby RedMist » Thu Dec 29, 2005 3:51 pm
Blacktop and silvertop injectors are identical. Rated 295cc flowed 315cc / min injectors. Your pulling some serious HP in order to need to replace them. Or if your ricing your vehicle by fitting larger injectors, expect to loose HP throughout the curve.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Ako » Thu Dec 29, 2005 3:53 pm
Ricing the vehicle / fitting a T28 to it, either or aye :wink:
Cheers for that though, much appreciated.
Ako
Postby Mr Revhead » Thu Dec 29, 2005 3:55 pm
haha oh yeah.... same part number. now why didnt i check that :oops:
Postby RedMist » Thu Dec 29, 2005 6:35 pm
You should easily pull 210hp from the black/silvertop injectors in a NA situation. Turbo won't support that much as the BSFC's worse.
RedMist
Postby sergei » Thu Dec 29, 2005 8:48 pm
and 20v injectors are HIGH IMPEADANCE (~13 Ohm)
