Pinking
Pinking
Postby Magua » Thu Dec 29, 2005 11:05 pm
I recently bought a 91 celica gtr. Thing is, it's pinking. Up to about three thousand rpm from memory. I put 91 in by mistake (my last car ran 91) and it started to pink. So I got rid of that as fast as I could and put in some 95, not much of a difference at all. Finaly about 13L of 98 and it appears to be gone. Maybe just a little bit at low rpm. :?
Now I don't believe most 1991 celicas run on 98 octance petrol, what could be causing this?
Magua
Postby CozmoNz » Thu Dec 29, 2005 11:10 pm
Timing to far advanced, petrol its not designed for :P
Rayne For President!
CozmoNz
Postby Magua » Thu Dec 29, 2005 11:33 pm
Well it's pretty far out if it's pinking on 95. I mean it's a 91 gtr. My Integra ran on 91. :P Is it an easy fix to retard the timing?
Magua
Postby Akane » Fri Dec 30, 2005 12:05 am
How do you know if it's "pinking"?
Is it just coz it's running rough or are you hear the pinking sound?
Postby Magua » Fri Dec 30, 2005 12:27 am
I can hear it. Loud and clear. Doens't appear to be running rough...though I don't have another celica to compare it to.
Magua
Postby AJz » Fri Dec 30, 2005 12:36 am
put 98 in it, i run it in mine, runs the best on that, havnt bothered to check my timing since i got it so im not sure what mines set at (too lazy) but yea, it ran like a sack on 91.
I had vtax :(
AJz
Postby Ae92typeX » Fri Dec 30, 2005 8:30 am
could always drop the timing back afew degrees and try that if you wish to run lower octane. Since 1991 anyone could have set it at anything.
if you havent already(you state you bought recently), take the opportunity to replace all the servicable units- plugs etc etc.
Ae92typeX
Postby Magua » Fri Dec 30, 2005 8:54 am
I'm changing the oil and filter today, I'll get onto the plugs and leads etc if I have the time today.
Thanks for the advice.
Magua
Postby MrBeef » Fri Dec 30, 2005 7:30 pm
what sound does it make when its pinking...
cos my rocker cover is pretty noisey aye...heh...
my 4a-f is said to run on premium..but i said neh!~ 91
Any last words?
Box, toaster, Aluminum, Maple syrup...no I take that back..im'a hold onto that one.
My beast!
MrBeef
Postby Dell'Orto » Fri Dec 30, 2005 7:53 pm
MrBeef wrote:what sound does it make when its pinking...
Get a marble, drop it into a jar...thats about what it sounds like.
Postby Akane » Sat Dec 31, 2005 3:41 am
Mmm, Boost wrote:Get a marble, drop it into a jar...thats about what it sounds like.
That, or it sounds like a ticker machine when I was running 1.25 kg/cm^2 @ 6000rpm the other night :)
Postby Vertigo » Sat Dec 31, 2005 10:42 am
my 2A is pinking on 95 as well, which is mighty annoying as my petrol station has run out of 98.
whats a good octane to run a 2A on? i will adjust my timing if need be.
TVIS just kicked in, yo!
Vertigo
Postby Magua » Sun Jan 01, 2006 4:24 pm
Would resetting the ecu return the timing back to factory?
Magua
Postby Akane » Mon Jan 02, 2006 1:19 am
Yes, but as soon as you start driving the ECU will start making adjustments again based on the knock signal it receives (within a certain range ofcourse).
So you could try retard the timing by playing with the dizzy.
Postby solidog » Mon Jan 02, 2006 9:59 am
Akane wrote:So you could try retard the timing by playing with the dizzy.
...and break it... yeah!
-=4age inside ~ Allmotor Toyota=-
I know stuff, im modest, I get involved
Yeah newtown ae that me! Did you know "Newtown : Its a bit shit!" but not me!
solidog
Postby Magua » Mon Jan 02, 2006 12:31 pm
Sooo since I've got 98 in my tank, once I've reset the ECU it's just going to advance the timing to suit the higher octance petrol in my tank?
Also, how do I reset the ECU?
Magua
Postby Akane » Mon Jan 02, 2006 2:04 pm
Only if you're a retard.
Postby Ae92typeX » Mon Jan 02, 2006 7:36 pm
Magua wrote:Sooo since I've got 98 in my tank, once I've reset the ECU it's just going to advance the timing to suit the higher octance petrol in my tank?
disconnect battery , or pull the ecu fuse.
The ecu wont tune itself to your fuel by resetting the ecu. as Akane states, what it will do is alter it depending on the knock sensor (to a certian degree)- but thats not ideal for good running. Im assuming its similar to the 4age that you need to bridge two wires on the diag's box, then manually set the timing.
Ae92typeX
