sergei wrote:So what I'm trying to say is:
The speed of the conveyer will be double but in opposite direction of the plane or will be same as plane's and in same direction deppends how the conditions are interpreted.
vvega wrote:basically if you look at it carefully and think about it
the wheel will not rotate at all
this is the funtion of the converyer
so the plane will take off
the wheels would not rotate
and the convayer would match the planes groundspeed
v
sergei wrote:Also there is nothing preventing the conveyor to acclerate from its initial 0 state...
Think about a trolley on the wheels, initially it is at rest, if you try to push it it will move, why would it move - becuase it is relativile solid object and most of your energy (push) will transform into trolley kinetic energy. The initial rest state of the trolley does not prevent it from moving, otherwise the energy conservation law would go in the bin... (if trolley would not move for some reason the friction force or some other cause would transform your energy not in kinetic but into heat, another form of energy).
For same reason inital rest state of the conveyor belt does not prevent it from moving when thrust of the plane is applied.
RedMist wrote:What groundspeed is the plane doing at take off? Not sure, this couldn't be achieved with the original set-up.
What wheelspeed is the plane doing at takeoff? There is nothing to stop the wheels from accelerating, uuum close to the speed of light?
What speed is the conveyor doing (without rewording the original quesiton, ie it matches the wheelspeed in an opposite direction.)? hmmm, same as above but in the opposite rotation direction
What groundspeed is the plane doing?Same as question 1?
vvega wrote:What groundspeed is the plane doing at take off? enough to take off (dependant on the type of plave)
What wheelspeed is the plane doing at takeoff? the wheels are not moving
What speed is the conveyor doing (without rewording the original quesiton, ie it matches the wheelspeed in an opposite direction.)? the same speed as the plane turing in a direction that is to the end of the runway
What groundspeed is the plane doing? again its accellrating to takeoff speed
sergei wrote:hey my trolley can have maglev (magnetic levitation) - wheels will not rotate as there are none, or even it can have slides... rotation of the wheels is not esential for movement (hey living things don't have wheels, most of them move, and quet efficiently I would say)
sergei wrote:Q1)What groundspeed is the plane doing at take off?
A1)depends on the plane but it is reasonble finite value V(off) - ground speed is relative anyway, in this case ground speed should be speed relative to ground where is conveyor based, air speed relative to plane wings is more important. At the begining the plane is at rest V(off) = 0
Q2)What wheelspeed is the plane doing at takeoff?
A2)Wheelspeed - wrong term used there is no such thing as wheel speed, Speed is scalar quantaty - as for wheels angular velocity is more appropriate. The angular velocity of the wheel is irrelevant to planes ability to take off.
Q3)What speed is the conveyor doing (without rewording the original quesiton, ie it matches the wheelspeed in an opposite direction.)?
A3) see A2) for explanation on wheelspeed. The meaning of the sensece "matches the wheelspeed in an opposite direction" can be interpreted in many ways, but logical way is: the conveyor is set to counterreact any angular motion of the wheels, if so the angular velocity of the wheel would be 0 hence the energy applied from thrust of the plain would result in motion of the conveyor belt.
Q4)What groundspeed is the plane doing?
A4) see A1
sergei wrote:you are saying that "conveyer matches the wheelspeed in opposite direction", please explain how conveyer could rotate in opposite direction of the wheels if there is no slip??? What you will be pushing in your case, if conveyer is designed to counterreact movement of the wheels, is the conveyer belt with the trolley on it. I will repeat myselft again, there is nothing restricting the conveyer belt from moving forward with the trolley (or plane), as long as the control unit satisfies the condition that conveyer compensates for wheel movement.
RedMist wrote:vvega wrote:What groundspeed is the plane doing at take off? enough to take off (dependant on the type of plave)
The wheels are not moving, the conveyor is not moving. So my original questions stand. How does the plane take off without moving the wheels? IE Skidding?
Users browsing this forum: Bing [Bot] and 1 guest
