Wiring up reverse lights on t50
Postby AE85.6 » Fri Jan 06, 2006 2:40 pm
just wandering where the wires go that that lead from the plug on the gearbox too ? do they go back up the shifter hole or ?
a pic would be awesome if possible
cheers all
If you drink, and drift,
your a bloody lunatic
AE85.6
Up and away....
Postby jondee86 » Fri Jan 06, 2006 9:48 pm
On my 86 the wires that clip on to the gearbox switch are part of the
engine loom. They run forward and upwards under the floor of the car, and
then up the firewall into the loom. They enter the loom at about the same
place as the #4 cylinder injector connection.
Both wires exit the loom via the large multi-pin plug that connects the
engine loom to the on-car loom. This connector sits on the firewall pretty
much behind and above the cam covers.
Inside the car the backup light circuit is powered from Pin #C15 on
Junction Block #3 wherever that is ??? Red-Blu wire from JB to switch
and Red-Blk wire from switch to lights. Backup lights wired in parallel
with a common earth to the chassis.
Hope this helps :)
Cheers.... jondee86
Watch this space >>> <<<
jondee86
Postby AE85.6 » Sun Jan 08, 2006 1:03 pm
cheers man,
something to start with i think its only missing the first leg but all good to know.
AE85.6
