4age blue top trouble
Postby trdnut » Tue Jan 10, 2006 9:28 pm
Heya
I gotta ae82 GT corrolla my engine check light won't turn off. The car idles and goes fine but i gotta find out whats wrong.
I was looking for the square plug for the ecu, but this model only has two yellow plugs in the enging bay with no marking on them.
Any ideas or help would be greatly appreciated
(I would like to post pics of the plugs but just don't know)
trdnut
Postby matt dunn » Tue Jan 10, 2006 11:05 pm
the two yellow plugs on the LH side near the firewall?
One is a 2 pin and one is not a 2 pin.( 3 or 4 from memory?)
Bridge out the two pins in the 2 pin plug,
and count the flashes on the dash.
post back your result.
Matt
Postby trdnut » Wed Jan 11, 2006 9:17 pm
spot on, will check tommorow
Gio
trdnut
Postby trdnut » Thu Jan 12, 2006 5:40 pm
four flashes
any ideas?
trdnut
Postby MINTFX » Thu Jan 12, 2006 5:55 pm
MINTFX
Postby Mr Revhead » Thu Jan 12, 2006 6:00 pm
his is an early 4age, those codes are for later models....
havnt got the right ones handy but google should reveal all!
Postby 2LTR Rona » Thu Jan 12, 2006 6:20 pm
Mr Revhead wrote:his is an early 4age, those codes are for later models....
Like this one Rev ????? Cant remember where it came from :oops:
2002 Altezza, 1974 KE25
2LTR Rona
Postby Ae92typeX » Thu Jan 12, 2006 6:34 pm
thats the one. code 4 water temp sensor
Ae92typeX
Postby trdnut » Thu Jan 12, 2006 9:21 pm
Got it sorted, one of the plugs on my temp sensors wasn't conneted properly.
Gio :D
trdnut
Postby matt dunn » Fri Jan 13, 2006 10:45 pm
There is no fault code number 5
That is a list of codes for a NZ new car.
The jap imports had fault code 5 which is Oxygen Sensor.
NZ new ones did not have an oxygen sensor.
Matt
