hey there, ive done this conversion on my ae101 liftback
it used to have a 4a-fe and now has a silvertop in it
as for needing a cert, ive done many warrants at testing stations and had no problem. i have however converted my drums at the back to disks.
the brakes from a ae101 Trueno or Levin bolt straight on, and you have to change the handbreak cable aswel
as for the flywheel, you will need a 20v one, as the 4afe flywheel only has 6 bolts and the 4age on has 8. not 100% sure about the cluth but from memory it was the same. and the 4afe gearbox will fit
your 4afe wont have (mine ddnt) idle up pipes for the power steering and the 20v does, so theres 2 spare vaccum hoses
other wise she will bolt straight in
