How do you change gearbox oil in k-50 (AE85)
Postby mr pad » Sun Jan 15, 2006 4:26 pm
Can I take the shifter out and fill it through there? Is that a good idea? Do you have to drop the gearbox out or somthing?!?
Alex
mr pad
Postby no_8wire » Sun Jan 15, 2006 4:59 pm
there should be a bolt on the side of teh gearbox...you fit it up till it comes out of the hole.
no_8wire
Re: How do you change gearbox oil in k-50 (AE85)
Postby Low_Aa63 » Sun Jan 15, 2006 5:00 pm
mr pad wrote:Can I take the shifter out and fill it through there? Is that a good idea? Do you have to drop the gearbox out or somthing?!?
Alex
I think thats the way most people do it aye!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby beeker » Sun Jan 15, 2006 6:38 pm
I know on the T50 its done via a bolt/filler hole the side of the gearbox. There is also one at the bottom for draining it.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby vhpacer » Sun Jan 15, 2006 7:40 pm
You have to pump it in the side hole with one of those things that looks like a grease gun.
I dont know if you can pour it through the shifter hole
vhpacer
Postby mr pad » Mon Jan 16, 2006 9:00 am
Alex
Good shit. Worked a treat. Just gota do it slowly.
mr pad
