toyota liteace (2c fuel pump)
Postby Destroyer » Mon Jan 16, 2006 8:53 pm
hello there, i have just brought a toyota liteace, didnt cost me very much at all because desial pump is leaking, i have now striped it down the to point of taking the pump out but do not want to lose the timing untill i know that i have got everything marked and there is nothing else i should be doing/watching/marking. if anyone know about removing the fuel pump and time on these i would like to know. thanks
IF YOUR READING THIS...
YOUR FINISHED READING...
Destroyer
Postby fangsport » Mon Jan 16, 2006 9:00 pm
a friend done a 3C pump last week and said the pump can be removed without taking the pulley or belt off. i'm guessing there is a grub screw(or similar), holding the pulley section onto the main pump shaft that can be loosened, that allows the pump to be drawn out.
fangsport
