Aluminium fuel lines?
Postby BBBrad » Thu Jan 12, 2006 10:07 pm
This may seem a little strange, but Im in the process of setting up my to and fro fuel lines in my car. I can get hold of some very nice thickish walled ali tubing in 8 & 10mm. It bends very nice, looks good and from memory the specs well exceed efi fuel presures etc. I cant recall seeing any car etc with ali lines. Is this for saftey, legal issues? Is there any rules that say you must use steel/bundy type tubing?
My new car...99 mr-s
BBBrad
Postby solberg Fan » Fri Jan 13, 2006 9:08 pm
I found the Ltsa site on fuel lines:
http://www.ltsa.govt.nz/publications/vir-manual/general-vehicles/13-miscellaneous-v2-2.pdf
It just said that it must be made of a suitable material. But i dont know if you have tp get it inspected? There must be some one here that knows?
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby KinLoud » Fri Jan 13, 2006 9:37 pm
Alluminium and its alloys is much less resistant to fatigue cracking than steel, especially around high stress areas like joint, flares and fittings.
Steel is much more forgiving.
Ken
Ham
021 408 863
Postby BBBrad » Fri Jan 13, 2006 9:45 pm
Yea, that crossed my mind. But then I thought of the ac lines that run around the car. They must be sujected to a hole heap more stress/pressure/ heat differences etc than your average fuel line? I'm hoping that if I support it properly and dont do anything silly with it it shoud be just fine. I just hope that someone doesnt make me pull it all out in the end.
Someone must know for sure? You race guys must know?
Thanks
BBBrad
Postby vvega » Sat Jan 14, 2006 10:31 am
as long as they are correctly supported with runber inslated clamps they will be fine
they are used in aircraft and are subjected to a fair wack of vibration in there
another prolem you may have is alloy requires a slightly different angle flare to reduce fatigue cracks
you just also polish the tube and flares as any scratches or marks will be the point that it forms a crack
AN - fittings and flar angles are what your looking for :D
v
vvega
Postby BBBrad » Sat Jan 14, 2006 11:01 am
Thanks vvega, Thats what I wanted to hear. I suppose my car will be abit like a low flying aircraft anyway:)
BBBrad
Postby Santa'sBoostinSleigh » Thu Jan 19, 2006 9:27 am
just found this in the motorsport manual:
lines must be made of steel
http://www.motorsport.org.nz/Pdf/M33%20App2%20SchA.pdf
however, if its not a racecar it may be different
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby GT4 20 » Thu Jan 19, 2006 9:52 am
It may also be worth considering thet in the event of a fire in the cabin area that aluminium pipes will succumb to heat quicker than steel will. I know what type of material for fuelines I'll be using in my race car :wink:
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby vvega » Thu Jan 19, 2006 7:46 pm
GT4 20 wrote:It may also be worth considering thet in the event of a fire in the cabin area that aluminium pipes will succumb to heat quicker than steel will. I know what type of material for fuelines I'll be using in my race car :wink:
Gary
it might also be worth considering were the fuel tank is and where the fuel lines run to and from
they dont enter the cabin and they are about 5 foot long
normally its the rubber pars of the line that burn first..so the alloy is the least of your worries....
im hope your not building a race race you sema to be missing a few of the very simple fundimentals :d
tank sits in the tunnel
pump is about the middle
motor is in the back
v
vvega
Postby vvega » Thu Jan 19, 2006 7:54 pm
Santa'sBoostinSleigh wrote:just found this in the motorsport manual:
can you tell me where
ive looked though it and done keyword sheachs and the only thing i can find referance to in lines is the brake lines
i even looked upi everthing to do with fuel....
man thats a pile of stuf :D
v
vvega
Postby Santa'sBoostinSleigh » Thu Jan 19, 2006 9:43 pm
v
oops i actually think i lied there
just double checked and i think it was the brakes i was reading on
thats what happens when you are pretending to do work at work and really flicking between work/TS/sideways/MSNZ
my bad sorry!
Santa's Mega Sale
