1JZ vs 2JZ (Laying the myths to rest.)
Postby Silent Knight » Fri Jan 20, 2006 12:26 pm
Righto...forgot bout that. :oops:
I've e-mailed it to Simon so he'll post it up. I can't access my FTP site from work...
Silent Knight
Postby Boldy » Fri Jan 20, 2006 1:35 pm
Boldy
Postby Ako » Fri Jan 20, 2006 2:11 pm
That does make total sense. The 2JZ is over-engineered in every other way, so why would they have put a better designed head on something which isn't the "flagship" sorta engine?
Such a shame there's nothing decent you can put a 2JZ into (like you can with the RB26 into a cef/gts skidda etc)
Ako
Postby sergei » Fri Jan 20, 2006 2:48 pm
hey what about MarkII, Chaser etc? They are much better looking cars then any similar nissans ...
Postby Ako » Fri Jan 20, 2006 2:57 pm
I meant CHEAP cars you can swap it into. A chaser etc - may as well just buy a Mk4 supra in the first place :(
Ako
Postby Silent Knight » Fri Jan 20, 2006 3:00 pm
Older Chasers are becoming a bit cheaper. And those MKII Grandes. The older and teh newer ones of those both look pretty sweet.
Also there will always be the A70 Supra, Z20 Soarer + the Z30 Soarer. :wink:
Silent Knight
Postby Malcolm » Fri Jan 20, 2006 5:01 pm
Ako wrote:I meant CHEAP cars you can swap it into. A chaser etc - may as well just buy a Mk4 supra in the first place :(
AE86/5 or even better, TA2* or RA2* Celicas
I guess none of those are that cheap, how about an 80's cressida? :D
Postby evil_si » Fri Jan 20, 2006 5:13 pm
Ako wrote:That does make total sense. The 2JZ is over-engineered in every other way, so why would they have put a better designed head on something which isn't the "flagship" sorta engine?
bullshit.
im fitting one to an altezza at the moment.. :lol:
evil_si
Postby spencer » Fri Jan 20, 2006 5:17 pm
um *x8* chaser/cresta/mark 2/cressida? or even the next couple of versions newer are sweet. I bought a gx81 for $900 mint as just need to find an engine.
they look pretty sweet to me better than nissan options
spencer
Postby Si » Sat Jan 21, 2006 2:13 am
i assume it was a USDM head they checked?
Current: , '96 SubaruImpreza
Si
Postby Aging Hoon » Sat Jan 21, 2006 10:40 pm
Why not put one into a R32 Skyline Coupe and you have the best of everything, power, handling and reliability. Also not too difficult conversion.
Aging Hoon
Postby deaf_rattle » Sat Jan 21, 2006 10:50 pm
or a mk2 supra like norbie in australia
stock wheels, stock turbos, stock ecu, stock boost, street trim
12 second 1/4s
plenty of potential
Postby Defective » Sat Jan 21, 2006 11:02 pm
deaf_rattle wrote:or a mk2 supra like norbie in australia
12 second 1/4s
plenty of potential
and the mkII's are the only good looking supra's imo
Defective
Postby deaf_rattle » Sun Jan 22, 2006 9:43 am
12 second 1/4s
plenty of potential
i l ike the way you think :D
