drftnmaz wrote:damn you make that sound completed...
To translate that - Twin sequential setups are a waste of time and effort, just run one properly sized turbo (or two in parallel).
Ako wrote:And I still stand by the fact that sequential setups suck balls.
Ako wrote:I meant in terms of - if the turbo physically can't provide the flow needed. Think TD04 on 2L engine and you'll see what I mean.
Ako wrote:Uuurgh... This question is worded too confusingly for me!
fivebob wrote:Ako wrote:I meant in terms of - if the turbo physically can't provide the flow needed. Think TD04 on 2L engine and you'll see what I mean.
I understood what you meant, it’s just that your terminology was wrong, as is most peoples understanding of boost and flow. Boost does not provide power, flow does, boost level is just an indication of restriction in the engine.Ako wrote:Uuurgh... This question is worded too confusingly for me!
I think you will find that this is just a theory question, not related to the practicalities of running sequential turbos.
fivebob wrote:I think you will find that this is just a theory question, not related to the practicalities of running sequential turbos.
Stealer Of Souls wrote:So am I right? For a engine A 160CFM is max NA flow. So 320 CFM would be 1BAR and 480CFM is 2BAR. No matter how the flow is made (single biggie, many littlies), as long as the flow is there (160/320/480CFM) the boost level for engine A will be as said (0/1/2BAR).
Didn't seem like that much of a waste of time in the 2J...
Si wrote:Didn't seem like that much of a waste of time in the 2J...
or subaru.
CozmoNz wrote:arnt late model leggys single turbo again?
