by sergei » Thu Jan 26, 2006 5:11 pm
I was talking not about NOISE SUPRESSOR but LINE TRANSFORMERS.
You have to understand where the noise coming from.
Nose supressors are desinged to remove noise from power supply/charging system. But the problem with audio is that noise is supressed really well on power side of the things, while the signal side of of the amp is not, because of its nature the amp has a quiet high gain and the loop created by extra ground wire acts as a radio, amplifying all that wine. if you will hook up the speaker to battery thru transformer (to eliminate DC component) while the car is running, you will probably hear very little noise.
This ground loop eliminator box is connected to RCA cables just before amp, what basically inside is a transformer (1 to 1).
Have you heard of balanced, or twisted pair?
The reason behind that twisted pair performs better (SNR and bandwidth) then a good shielded coax, is that the external noise is canceld out in twisted pair (due to nature of it). Balanced XLR is like a twisted pair (but slightly different) vs RCA (wich is like a COAX, and basically is a low quality COAX).
Most of the alternator whine noise is coming from shielding on RCA cables. (due to ground loops mentioned above).
I agree noise supressors are waste of time and money, while groun loop isolation is not.
Have tried to insert RCAs half way (as outer contact - shielding, not touching the amp) you will see that noise wilh reduce alot.
