what rwd engine?
what rwd engine?
Postby Anth_555 » Thu Jan 26, 2006 7:45 pm
i have a 86 cressida with a 5m in it and i want to put a 4cly turbo moter in to it any 1 got ideas off what i could put in?
have looked in to a gt4 moter but will cost to much
Anth_555
Postby Alex B » Thu Jan 26, 2006 7:47 pm
Well a gt-four engine isnt rear wheel drive for one so funny that. Please type out you post properly people round these parts dont respond to well to txt speak and rightly so.
Postby Anth_555 » Thu Jan 26, 2006 7:57 pm
yea but you can get the stuff to make it rwd but it cost alot any way do you have an ideas?
Anth_555
Postby Malcolm » Thu Jan 26, 2006 7:59 pm
why 4 cylinder?
if it already has a 5M in it, then a 7M-GTE (3L 6cyl turbo) conversion will be a piece of piss and more rewarding than a 3S-GTE. If you're too cheap for a 7M then a 1G-GTE (2L 6cyl twin turbo) would be a slight improvement over the 5M, but not really worthwhile.
Postby Jebus » Thu Jan 26, 2006 8:00 pm
SR20
Jebus
Postby Rob_GTZ » Thu Jan 26, 2006 8:02 pm
In all honesty you're making it quite hard on yourself, what is the reason for wanting a 4 Cylinder motor?
The better & much easier option would be to stick with the M Series motors, by either turboing the 5m, or transplanting the 7mgte. Either would make a great upgrade, and you would save yourself all the hassle of customising engine mounts etc.
However if you're really set on a 4cyl motor & don't mind all the custom work, a Nissan SR20DET would be a good choice.
Rob_GTZ
Postby CozmoNz » Thu Jan 26, 2006 8:07 pm
Jebus wrote:SR20
haha, Funny man.
You have the room for a 1uz / 2jz / 1jz / 7m, yet you wanna put a 4cyl in? why?
Rayne For President!
CozmoNz
Postby Anth_555 » Thu Jan 26, 2006 8:08 pm
i dont no y i want to go 4 cylinder i have been asking round and sticking with the 5m or upgrading to 7m is the best but im geting pised off with trying to find a manuel converstion and havent really had any luck with finding a 7m or a manafold 2 turbo mine mostly im getting pissed off with finding a bellhousing and fly wheel for the m`s
Anth_555
Postby Anth_555 » Thu Jan 26, 2006 8:10 pm
well cozmonz 1uz is the v8 aye and i dont really what 1 and i dont have the money for a jz and not having luck with the 7m + i want a newer engine
Anth_555
Postby Jebus » Thu Jan 26, 2006 8:17 pm
Anth_555 wrote: im geting pised off with
Anth_555 wrote: mostly im getting pissed off with finding a bellhousing and fly wheel for the m`s
Seems like you get pissed off alot
Jebus
Postby Anth_555 » Thu Jan 26, 2006 8:19 pm
yea m is old and rear thats y i want 2 change moter
Anth_555
Postby Si » Thu Jan 26, 2006 10:56 pm
how much money do you have to throw away on a old shitter?
Current: , '96 SubaruImpreza
Si
Postby Anth_555 » Fri Jan 27, 2006 7:08 am
no alot
Anth_555
Postby Leon » Fri Jan 27, 2006 9:20 am
Sell it and buy something more modern, unless you're a mechanic, otherwise you're going to spend a lot of money to go not much better.
Also, you are a lot easier to understand when you use actual words, not text speak.
Postby Jazza » Fri Jan 27, 2006 1:21 pm
Agreed, time for a new car :wink:
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby strx7 » Fri Jan 27, 2006 2:14 pm
its a 6 but a 2JZGE & autotrans, ecu loom etc etc etc etc $1400+F+gst
just need to alter the sump 225HP bucket loads of torque
Postby Anth_555 » Fri Jan 27, 2006 5:29 pm
na im stating with the cressida thaks they are a mint car i think i will got with a 7mgte best way 2 got and cheaper then a 2jz
Anth_555
Postby Quint » Fri Jan 27, 2006 5:37 pm
Get the 1G FAR superior engine :twisted:
:( i'd go with a 2JZ if i was to do a conversion like that, might as well spend the extra few hundred.
Quint
Postby Emperor » Fri Jan 27, 2006 7:14 pm
Emperor
Postby Malcolm » Fri Jan 27, 2006 8:20 pm
Quint wrote:Get the 1G FAR superior engine :twisted:
Far superior to what? a 4K?
