I didnt know my car smoked!!!
Postby [A NINJA] » Thu Jan 26, 2006 8:16 pm
Hey all, right te o. I have a 97 carib BZT (black top 4A-GE) 6spd, Its got 110k on the clock, its been well mantained etc. I overtook someone just before and it blew out big smoke from 4k-7500RPM. any ideas whats wrong. I continued home giving it a little of gas to see if smoke came out, and every time it blew a little smoke. I was a gray looking smoke and I barely thrash my car and I always let it warm up before driving.
please help!!!
www.tusken-raiders.tk
NINJA!!!!!!!!
[A NINJA]
Postby Low_Aa63 » Thu Jan 26, 2006 8:29 pm
what fuel are you running and what grade engine oil??
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby [A NINJA] » Thu Jan 26, 2006 8:32 pm
95( I know I should be running 98 but all the BPs Ive been to said they are out of stock!) And I have no idea on the oil it got seviced 1000kms ago
NINJA!!!!!!!!
[A NINJA]
Postby CozmoNz » Thu Jan 26, 2006 8:33 pm
As long as shes not blue :D
alot of 20v's ive seen without cats (have you gutted / removed yours?) etc just run fairly rich... end result, alot of fuel out the arse!
Rayne For President!
CozmoNz
Postby fx gt » Thu Jan 26, 2006 8:39 pm
dam car!nicorotte gum for her
fx gt
Postby [A NINJA] » Thu Jan 26, 2006 8:41 pm
I dont think the cat is gone/ gutted as the only noise you hear from my car is the manifold/ induction noise!!
NINJA!!!!!!!!
[A NINJA]
Postby fx gt » Thu Jan 26, 2006 8:43 pm
u dont know where ur cat is?
hope u find the poor we thing :O
fx gt
Postby Dell'Orto » Thu Jan 26, 2006 9:39 pm
You've got a different ECU dont you? Japanese "tuned ROM"s tend to have lots of fuel and lots of timing, so its probably dumping way more fuel than it needs. If you got hold of a stock ECU, it'd more than likely stop.
Postby Santa'sBoostinSleigh » Thu Jan 26, 2006 9:59 pm
hmm if you do have an aftermarket one, i'll swap you for my standard one :D
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby sergei » Thu Jan 26, 2006 10:12 pm
when idling open your oil cap (slightly) and see you have smoke coming out of there and if the cap is pushed out (bad) or sucked in (good). also take off the intake pipe and see if you have exsessive oil in there...
check exhaust black stuff in it feels greasy. Does it puffs smoke in the mornings just after you started it?
Take of spark plugs and check if the are covered in oil or exsessivly black.
Thats about it what you can do without leak down/compression test.
Also could be BHG (highly unlikely- otherwise it that stage would be running on 3 cylinders under load)..
Postby Low_Aa63 » Fri Jan 27, 2006 1:07 am
i doubt it would be blow by.. its just running rich when he puts his foot down and more than likley when its on vvtil... w\maybe retard the timing a litlle but i dont know if that would have any detrimental effects...
The list so far
Low_Aa63
Postby Mr Revhead » Fri Jan 27, 2006 10:01 am
my SARD ecu cleaned up my black smoke, not blows grey :D
.... 20vs run quite rich stock. mine chugged like a train on the stock ecu
hard to say with out seeing it but grey smoke is normal with these under full throttle.
Postby Alycia » Fri Jan 27, 2006 10:08 am
[A NINJA] wrote:95( I know I should be running 98 but all the BPs Ive been to said they are out of stock!) And I have no idea on the oil it got seviced 1000kms ago
Go and see Chickenman at BP2Go Halswell - They are constantly being supplied 98 octane.
Anyway - A few months ago I got home and locked the car and went to go inside - walking behind my car and smoke was coming from the exhaust - but my uncle said it was related to the cat as it had only been used for driving round town.
He told me to take it some where and give it a "GOOD BLOW OUT"!!! :wink: :lol: :twisted:
Which I did and I havn't had the problem since.
Alycia
Postby Chickenman » Fri Jan 27, 2006 10:49 am
Maybe not constantly but we're higher in the pecking order so we usually have it.
If not at least put some octane boost in the 95. I remember Alycias car before redline on 96 and it used to feel... "soft" probably because the ecu was pulling back the timing too much. 98 is an improvement but I still wouldn't go thrashing a blacktop on our fuels mercilessly.
Baby Jesus
Chickenman
I Am The Walrus!
Users browsing this forum: No registered users and 35 guests
