Ive got a 4agte.
Long story short engine went bang. The 4age was a redtop bigport tvis engine (10:1 or something close) running 8psi, standard compression ratio. It was tuned for 8psi. I have a 4agze which is going in shortly (8:1) and I know I need it to be re-tuned because of the compression difference.
So if im thinking correctly.. since its tuned for 10:1 running 8psi, if I didn't get it re-tuned there will be way to much fuel on the 8:1 4agze running 8psi correct?
Is it possible for me to boost a few more pounds, say 10-12psi so it won't be to rich? I was wondering if anyone would be able to help me out with this, even if there is no possiblity of simply upping the boost i am still rather curious to know.
EDIT: And im not using the 4agze computer when I swap the engine.
