fivebob wrote:Here's one for the 3MZ with the correct table, but I notice they read from the top down
matt dunn wrote:fivebob wrote:Here's one for the 3MZ with the correct table, but I notice they read from the top down
Why is there only four makings shown when there are 5 bearings aren't there?
well i got a block and we had to line bore that as it was out of wack
fivebob wrote:The difference between bearing the minimum size shell # 1 and a maximum size bearing shell #3 is only 4 tenths, so you should still have clearance, if only 2 tenths. Minimum clearance on #3 is 1 thou so you should have even more clearance there.
fivebob wrote:But that would only happen if there was something wrong with the bearing cap. There's not enough difference in the shell sizes to do that, certainly not between a #1 & #3 shell. Even the difference between a #5 & #1 shell (6 tenths) would only result in zero clearance on the sides, not an interference fit.
