caldina gtt turbo:just what the hell is it exactly?....
Postby Mr Revhead » Wed Feb 01, 2006 2:41 pm
for some odd reason toyota didnt cast a lug on the top of no1 port for a stud. so there is not a lot holding the manifold at that end.
as such they warp and/or pull the bottom stud out or rattle it loose. causing more warpage therefore ruining the manifold.
the facelift/superceded part has an extra lug and you just put another stud in. there is already a hole there in the head for it.
we'v done about 5 here alone. and iv supplied 12 to a place in auckland....
Postby Skin » Wed Feb 01, 2006 5:53 pm
yeah and then you get the more extreme thing happening....
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby Mr Revhead » Wed Feb 01, 2006 5:56 pm
lol bloody hell, some one ignored the leak for a looooong time 8O
Postby kilowatts » Wed Feb 01, 2006 7:21 pm
Ha, that is funny mine has just done that exactly. Sounding like a tractor at the moment. But what is funny is the impellor on mine is steel also which i thought were supposed to be ceramic.
current rides: 1994 toyota hiace, 1998 toyota hiace, 1998 toyota supra/na,2000 toyota caldina gtt,(1993 toyota fxgt has just been sold)
kilowatts
Postby fivebob » Wed Feb 01, 2006 7:33 pm
kilowatts wrote:But what is funny is the impellor on mine is steel also which i thought were supposed to be ceramic.
Not supposed, more like assumed to be ceramic because all that came before them were ceramic. There's long been rumours that the GTT came with a steel impellor, but no reliable proof has been put forward.
Postby vvega » Wed Feb 01, 2006 8:58 pm
yeah do us all a favour and smash the turbine on the ground a fw times :D
if it bends its steel
if it chips off its ceramic
"disclamer"
i am not liable for you distroying your perfictly good turbine whilest conductiong this test
this may or maynot be good advice
and may or maynot have been givin by a fictional person
thank you for your time :D
v
vvega
Postby Skin » Wed Feb 01, 2006 9:55 pm
hahaha i did the sound test-tapped the ct26(thud thud) tapped the ct15bzt%whateverthehellitis (ting ting)...perfect scientific testing...
that and the blades are a lot thicker on the ct26...
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby rodstr » Thu Mar 16, 2006 4:57 pm
Mr Revhead wrote:for some odd reason toyota didnt cast a lug on the top of no1 port for a stud. so there is not a lot holding the manifold at that end.
ok i just got my car in for repairs as my exhaust manifold has warped, the mechanic decided to get the manifold planed, is this such a good idea?
rodstr
Postby vvega » Thu Mar 16, 2006 6:20 pm
planing ke it straigth for now
but it will make the flange thicker and thinner in spots this will make it prone to warping
faceing off a flange sress relives the face....dosent mean it wont warp the other way as you mill it ethier
;d
v
vvega
Postby Mr Revhead » Thu Mar 16, 2006 10:05 pm
yeah we tried that too. car was back in a month later for new manifold/turbo
Postby Wildcard » Sat Mar 25, 2006 8:07 pm
So, it would appear my Blitz turbo has the pre-facelift manifold and as luck would have it seems to be leaking along the area in my photo here:
Not sure if its a warped manifold or if the CT20b gasket I used has expired - Turbo only has 25k on it.....yawn.
At either rate when I checked today the far left nut had only ~35NM of torque applied while the others were fine at around 60NM.
What are my options if the manifold is warped? I assume with some fab work a CT20b manifold could be adapted to fit?
...Vvega? ;)
Wildcard
Toyspeed Founder
Postby TWSTD » Sun Mar 26, 2006 12:30 am
GEN3 manifolds bolt right up with the extra stud too - I ran one for a while ben when i had the CT26/To4 hybrid.
AL
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby vvega » Sun Mar 26, 2006 2:49 pm
Wildcard wrote:So, it would appear my Blitz turbo has the pre-facelift manifold and as luck would have it seems to be leaking along the area in my photo here:
...Vvega? ;)
lol you called oh dependant one :D
basically ben we could cut the flange off and weld on a new one that would allow you to bolt it to the 9 stud manifold :D
or even a prefabed bling thing if your inner racer so desires :D
ill make a effort to be on msn later
v
vvega
