KinLoud wrote:hoses or pipes?
Ken
Ham
021 408 863
Si wrote:if you want bling samco make replacement sets.
SAMCO silicone radiator hosese are specifically designed to withstand the extreme temperatures and corrosive nature of coolant and oils. SAMCO radiator hoses are designed to maintain maximum coolant flow while eliminating common radiator hose problems such as cracking and corroding. SAMCO radiator hoses are built to withstand extreme temeratures from -50 degrees Celcius to 200 degree Celcius. SAMCO silicone radiator hose kits are also specially designed for each application for a perfect fit.
I assume this is overkill ? Maybe if i had a hi temp turbo application ?
http://www.alertmotorsport.com are a NZ company whos website lists them, nothing else comes up with google however
SUBARUCONVERT wrote:AFAIK gates makes many OE belts anyways? i dont see why the toyota one would be majorly better in anyway
