Any electronic wizzos out there?
I'm lookin at making the WAI more efficeint on my GT4. After lagging the bottom of the unit itself, I'm getting a larger pre-rad made up and would like to rig up a decent water spray unit to help increase the heat transfer.
The WRC version does already come with a non functioning system, but I'd like something a little more trick.
A high power pump, nozzles etc aren't an issue - what I'm looking at doing is fitting a system which is boost activated and will run for say 3 seconds, switch off for 3 seconds, switch on for 3 seconds, etc while on boost. That way, any water mist on the pre-rad will have time to evaporate before the next lot is sprayed. Otherwise there is the risk of too much water collecting on the rad which will then fail to evaporate and as a result, it won't transfer the heat.
Any idea what electronic parts I need to get?
Gary
