Yeap, my motor was built by glenn.
But heres a few things.
Basicly with a factory 7afe block with blue top head, the peak power is about the same at the same revs. The big advantage of the 7a, is the torque, it feels so diffrent to a 4-age, I love it. I have only just in the last week really started exploring the posibiltys of where this motor can go.
You have to remeber that in a simpl build, your running pretty lo compresion, I havnt check what it is running at yet.
Ecu wise im running a link, in all honestly, I would feel your probabl just wasting time using any stock ecu, the power gain can be huge by just this simple change. If you talk to the garage dori guys, they swear by a fuel ecu called mega squirt. Google it, there is a lot of support on the net for this ecu.
From what I have read, people wouldnt sugest aiming for more that 250whp on the factory 7afe rods.
Heres a tech article from
http://www.club4ag.com, which would be one of the best places to start to learn about 7age,s there is alot of expericance there.
http://www.club4ag.com/faq%20and%20tech ... d%207A.htm
As for converting pistons to gze, its the same as any other age motor, as long as the gudgen pin is 20mm (I think) then they fit. I know grottys motor has gze pistons in it. Another thing with the piston is deciding what comprsion ratio's your after, gze's come in 8.9:1 and 8.0:1 (roughly). So if you want crazy boost then the lower compressions going to be better, but also a waste of time. Boost would come on like a light switch, due to the longer spool time of the turbo.
Also I nkwo there are a few guys in the us that are running these with factory cam wheels. Dont waste your time, timing on a motor can make all the diffrence. Adjustable cam gears are really a must.. Also ther are a few diffrent options for what belt to run with. And each type determinds which belt tensioner to use.
Any questions just ask and will try and answer, but like I said, hit the
http://www.club4ag.com forum, and run a search on 7agte's, theres lots to read.
Look for the thrad by team66, hes got some good experiance
Allan
Mr XXX
