please note i am in no way advocating running your toyota cam belt for 130000 kays!!
gates are adequate. toyota are good
SUBARUCONVERT wrote:I dont see many stock toyotas making 600hp, Enzo vs a 4afe corolla. bit of a miss match there.
SUBARUCONVERT wrote:if the toyota ones only last 30k over 100k then they must be crap, ive seen a number of 200k old subaru timing belts at work (this is going off how u were talking). Therefor everyone should buy subaru belts for there toyotas
HRT wrote:Half the load but twice the number of cams to drive and they're on a single beltWell, most of them
Mr Revhead wrote:interesting to note that toyota are now going back to chains.
There may only be 2 pots per cam, but have 4 cams vs 2 must make for more friction and a higher belt load. Also being 2x the length of a usual twin cam belt must make it more suspetible to breakage/failiure (altho being longer lets the belt do less rpm than a normal one so takes some stress away). also using ur logic, V6 toyotas must be able to have an extended belt life over the V8 and L4 engines, but thats not the casefivebob wrote:SUBARUCONVERT wrote:if the toyota ones only last 30k over 100k then they must be crap, ive seen a number of 200k old subaru timing belts at work (this is going off how u were talking). Therefor everyone should buy subaru belts for there toyotas
Lets see, assuming a four cylinder opposed engine, that's half the number of cylinders per cam drive, so slightly more than half the load per belt. Suprised they don't last 250,000kms or more![]()
Even if it was a six cylinder opposed, or 3 cylinder in line that'd be 3/4 of the load so 200,000 vs 130,000 seems about right ...Next
BTW you'd have been better off picking a Honda as your example (though there's flaws with that argument as well) a lot of them have 160,000 service intervals.
SUBARUCONVERT wrote:There may only be 2 pots per cam, but have 4 cams vs 2 must make for more friction and a higher belt load. Also being 2x the length of a usual twin cam belt must make it more suspetible to breakage/failiure (altho being longer lets the belt do less rpm than a normal one so takes some stress away). also using ur logic, V6 toyotas must be able to have an extended belt life over the V8 and L4 engines, but thats not the casefivebob wrote:SUBARUCONVERT wrote:if the toyota ones only last 30k over 100k then they must be crap, ive seen a number of 200k old subaru timing belts at work (this is going off how u were talking). Therefor everyone should buy subaru belts for there toyotas
P.S subarus new EZ sixes use a cam cain also, but to make the engine shorter
vvega wrote:just out of intrest the genuine belts are made by gates
Gates Unitta Asia - A joint venture between The Gates Corporation of the United States and Nitta Corporation of Japan, partners in Asia for over 30 years. This new organization will manage and coordinate all our existing power transmission business activities in Asia.
