4AGZE from AW11 into a KE70 Sedan
Postby DR ROTOR » Thu Feb 09, 2006 3:18 am
hey there i currently have a 1982 toyota corolla dx sedan.. it currently runs a 4K 4 speed.... im wanting to put a 4AGZE into it.. i have my eyes on a 1987 Supercharged MR2 AW11 complete car wrecking. just wondering if the motor will drop into it, without any major modifications? i understand that i will need the cross member/mounts custom made... but will the AW11 gearbox fit into my ke70? are they a T50?, i got loom computer etc just wanting to know what i need for the conversion?
Thanks
DR ROTOR
Postby no_8wire » Thu Feb 09, 2006 7:37 am
The gearbox on the AW11 is a E51 I believe. Plus you will need to turn the shifter linker?...around.... but know it will not fit as its a FWD gearbox..
no_8wire
Postby slighty_sykotic » Thu Feb 09, 2006 12:08 pm
No it won't fit, unless the ke70 is also fwd....
Or you are going to stick the motor in the boot :P
You could use a t50 though if you wanted to, just get ahold of a 4a - T50 bell housing.
--Sykotic
slighty_sykotic
Postby Dell'Orto » Thu Feb 09, 2006 1:11 pm
Your standard K40 gearbox would last, oooh, maybe a day on the back of a 4AGZE, the torque would shred it.
Try fine a T50 gearbox, they actually bolt onto 4AGE's, but with abuse that would die too.
If you were going to do it properly, and had intentions of making more power/giving it a hiding in the future, then look to a W series box. You'll need to do the diff as well, as its not really designed for much horsepower.
Its not a straight forward drop it in she'll be right conversion, but its not terribly hard either. Plenty of info about if you search.
Postby DR ROTOR » Thu Feb 09, 2006 1:12 pm
allright thanks for the help, so pretty much i need to find a gearbox maybe a T50 or something? and after that it should be easy? ,, also rwd exhaust manifold is that true?
DR ROTOR
Postby Alex B » Thu Feb 09, 2006 1:17 pm
Um since its going into a RWD car then yes that would be true. Sorry, dont mean to sound harsh but you do have some idea of what your doing dont you?
Postby DR ROTOR » Thu Feb 09, 2006 2:29 pm
yeah! but never got a motor from a MR2 and have no idea about the gearbox.. thanks
DR ROTOR
Postby Alex B » Thu Feb 09, 2006 2:31 pm
OK well an MR2 setup is basicly a FWD in teh back of the car.
Postby rotorchiki69 » Thu Feb 09, 2006 4:40 pm
u use a ae86 x member a t50 or w55 gearbox only thing u can use fro the mr2 is the engine itself no accesory u need waterpump altenator bracket and all accesorys from an ae86 also need aa hydrolic clutch welded in
rotorchiki69
Postby 2LTR Rona » Thu Feb 09, 2006 6:17 pm
DR ROTOR wrote:yeah! but never got a motor from a MR2 and have no idea about the gearbox.. thanks
flick me a PM with you email addy I have a few docs and links on the 4A series of engine, dropping on in to an AE86 (not the same i know, but will give you quite a few andswers) and probably have some good URL's as well 8)
I am heading down this track with the KE25 latter sometime this year
2002 Altezza, 1974 KE25
2LTR Rona
Postby suberimakuri » Fri Feb 10, 2006 6:33 pm
buy my ae70 crossmember on trademe and then drop your 4agze straight onto the crossmember with factory rwd mounts.
suberimakuri
