i ran a 12.949 at 110.8 mph at masterton on sat 4th feb. in my soarer, it has standard turbos and ECU,running 15psi.Has front mount cooler, 3" exhaust,and shift kitted auto trans,and drag radials. Go the jz motors!
BlakeNZ wrote:i ran a 12.949 at 110.8 mph at masterton on sat 4th feb. in my soarer, it has standard turbos and ECU,running 15psi.Has front mount cooler, 3" exhaust,and shift kitted auto trans,and drag radials. Go the jz motors!
The trans is just stock, the car was full trim even had the spare in the boot, and full tank of gas and 16psi boost.gmacrae wrote:downloading the vid now, damn dialup. Its a jza80? where did you get your tweaked trans from John? What'd that set you back?
Gene
Thats alsome Blake the best time i got on the twins was a flat 13sec running the same boost so well done.BlakeNZ wrote:i ran a 12.949 at 110.8 mph at masterton on sat 4th feb. in my soarer, it has standard turbos and ECU,running 15psi.Has front mount cooler, 3" exhaust,and shift kitted auto trans,and drag radials. Go the jz motors!
