SW20 Gearbox.
SW20 Gearbox.
Postby Silent Knight » Sat Feb 11, 2006 11:47 am
Quick couple of questions here easily answered:
Car = 1990 N/A SW20 5M/T
1. What is the fluid capacity of the gearbox?
2. What grade fluid is best to use for the gearbox?
3. Where on the gearbox is the drain and fill plugs?
The gears in my partner's car is starting to crunch a little bit so I thought first thing to do is flush it out and get some fresh fluid in there and see how it goes.
Cheers for the help.
Hanré
Silent Knight
Postby Wildcard » Sat Feb 11, 2006 2:35 pm
1) http://www.mr2-tech.com/bgb/mechanical/ ... nsaxle.htm
2) I use and recommend redline and have not had any problems with it, however its expensive and probably unnecessary here
3) http://www.mr2-tech.com/bgb/mechanical/ ... axle/2.htm
Wildcard
Toyspeed Founder
Postby vvega » Sat Feb 11, 2006 2:36 pm
redline sucks dogs balls :D
v
vvega
Postby Silent Knight » Sun Feb 12, 2006 3:33 pm
Thanks Ben for the sockets!!
It's all done now.
And I would like to give a biggy ups to Chris (GT4SUM) for making me do twice the work because he played around with the position of the bolt on top of the gearbox for the shifters. Which means after I put everything back on and back together the gears couldn't change and I had to take it all apart again. :?
BLOODY FIDDLERS!!!!
Silent Knight
Postby Infinite » Sun Feb 12, 2006 3:52 pm
lol guted
Lots
Infinite
Postby Wildcard » Sun Feb 12, 2006 6:05 pm
Silent Knight wrote:And I would like to give a biggy ups to Chris (GT4SUM) for making me do twice the work because he played around with the position of the bolt on top of the gearbox for the shifters.
Hmm, 'told you so'. :roll:
Wildcard
Toyspeed Founder
Postby Silent Knight » Sun Feb 12, 2006 6:31 pm
Yes...which is why I didn't fiddle with it and just left it. Chris however thought it was looked shiney and pretty and started fiddling which I only found out after I started teh car again.. :cry:
Silent Knight
