Adydas wrote:fivebobso vvegas wrong?
fivebob wrote:Adydas wrote:fivebobso vvegas wrong?
Sort of....Correct in that it will work but kind of wrong in that you shouldn't have to re-wire(unless you have a ST185RC). Even that's not quite right because IIRC there's some additional wiring to fit the MAT sensor for the PowerFC.![]()
Anyway for your reference (provided you can read Excel spreadsheets) the pinouts for the various ECUs can be found at;
http://www.users.on.net/~fivebob/Pages/3SGTE-PINOUT.xls
All_Fours wrote:wiring loom needs to be changed to suit ecu. If it's a matter of 8 or so pins being different that's a pretty easy task, just remove the pins from the back of the plug and swap them to the correct spot (or cut + solder/crimp if the plugs are different)
fivebob - where were your RC pin out diagrams 3 years ago when I was looking for them!?
fivebob wrote:fivebob - where were your RC pin out diagrams 3 years ago when I was looking for them!?
On my computer, and on the Japanese website where I found them
ST185 has WIN pin where the SW20 has an ABS pin, not sure what either pin is used for (input/output?) or if they're required. My guess is that The ABS pin is not needed on the ST185 so the ECU will still function correctly, but I don't know if WIN signal is an output and may me needed, or an input and therefore not required.
vvega wrote:i belive the" rly" is the output to control the pump
its bascially a ecu controled switch based of throttle position
evp is quite posiby not connected on cliffs car as it should be the EGR valve position sensor ??
All_Fours wrote:There's a small VSV by the charcoal cannister on the RCs which is probably connected to EVP
All_Fours wrote:vvega wrote:i belive the" rly" is the output to control the pump
I don't think it is, the intercooler ECU controls the operation of the pump and there is only one wire going from intercooler ECU to engine ECU and that's WIN.
