Heat Wrap
Postby Bazda » Fri Feb 17, 2006 12:15 am
Jebus wrote:I did mine with Dytech stuff from nzperformance, its good stuff, yep wetting it is the best advice, makes it nice to put on and welding wire is awesome for fixing it at the ends, looks mmuuuchh better than cable ties. I wuldnt trust the cheap sh*t off trade me, I bought a bit of it, and it caught fire on my extractors :( The dytech stuff made a huge difference, did my extractors and half way down my piping, then just the section over my diff.
I fix it down with lock wire, its like there is nothing there cos the wire is so thin :D
Postby barryogen » Fri Feb 17, 2006 8:00 am
pardon my ignorance, but...
what does it do other than keep the heat in the pipes?
is it to do with keeping it hot to keep the exhaust gas speeds up or am I completly confused?
Does it also quiet it down a bit?
While asking questions, adding additional pressure to radiator, other than upping the boil temp, what does it do, and how does upping the boiling temp help anything?
barryogen
2ZZ Guru in training
Postby Bazda » Fri Feb 17, 2006 8:31 am
barryogen wrote:pardon my ignorance, but...
dont think wrapping ur headers will change the boiling temp....dont see how it will change any temps at all, it will prob keep the engine bay cooler and help with water temps.
Postby Stealer Of Souls » Fri Feb 17, 2006 8:51 am
Hmmm... On my ae85 I wrapped the factory manifold on my 4AGE down to a flange where the original cat would've been. I tried to keep the overlap to around 1/2, and I think it took a bit less than 15m. My friend got it for me from a marine store for reasonably cheap, i think he said it was around $50 for the amount I used.
From my understanding the main reasons for heat wrap is to keep the heat in the exhaust for two reasons. One to keep the exhaust speed up, but more importantly (on the manifold/extractors) is to keep the heat out of the engine bay. Supposed to put less heat strain on everything else in the bay help it all to last longer, and work more efficiently for longer.
As a side bit, it does help a bit with exhaust noise. But really most effective at that if you wrap the whole exhaust.
Increasing boiling temp is just a way to try and stop engine overheating. Assuming the boiling temp isn't above the engines proper operating temperature the increase allows the radiator fluid to absorb more heat before it boils. When it boils radiator fluid absorbs a lot of heat, but after that it becomes practically useless...
'86 AE85.5 Levin
Stealer Of Souls
Postby barryogen » Fri Feb 17, 2006 9:16 am
Bazda wrote:dont think wrapping ur headers will change the boiling temp....
you seem to have mis-understood, they were two seperate questions.
barryogen
Postby barryogen » Fri Feb 17, 2006 9:18 am
Stealer Of Souls wrote:From my understanding the main reasons for heat wrap is to keep the heat in the exhaust for two reasons. One to keep the exhaust speed up, but more importantly (on the manifold/extractors) is to keep the heat out of the engine bay. Supposed to put less heat strain on everything else in the bay help it all to last longer, and work more efficiently for longer.
Thanks for that, I figured it was something along those lines.
again, thanks, I'm learning fast, but some of the little things just confuse me
barryogen
Postby bad20v » Fri Feb 17, 2006 10:07 am
vvega wrote:
bad20v wrote:
Wear Gloves!!! Fibreglass Hurts If It Gets In Your Skin!!!
8)
your one of them girly boys now then aye :D
i use that sh*t to wipe my arse :D
v
Pics Or It Never...... Ummm maybe not!!! :?
I would dare you to wipe your arse with fibreglass!! Especially the Pink Batts type, but I don't think anyone would notice that you did as you just be scratching your arse all the time as you usually do. :P
Thank-You.
bad20v
Postby RomanV » Fri Feb 17, 2006 10:13 am
Dont underestimate Vvega's hardcoreness.
I hear that he cleans his teeth with a wire brush, puts dynamite on his weetbix, is 8 feet tall, and shoots fireballs out of his arse.
Postby bad20v » Fri Feb 17, 2006 10:29 am
RomanV wrote:Dont underestimate Vvega's hardcoreness.
Oh come on, I have met the man himself, and he's not that hard....
....except for his best friend..... The I Don't Care Burger!!! 8O
So tell the burger that cares.... really tell it how you feel! :lol: :lol: :lol:
Thank-You.
bad20v
Postby Silent Knight » Fri Feb 17, 2006 11:00 am
No you've all got it wrong. Wayne is actually a big pussy trying to be kool by having 100s of parts and tools lying around his garage so it looks like he's busy doing something when he's actually not.
That 1UZ has not moved an inch from where I saw it last before Xmas Wayne!!! :P
And it's not the I Don't Care Burger...It's A Care Burger, Why? ...Cuz it Cares Damnit!!!
Silent Knight
Postby Jebus » Fri Feb 17, 2006 2:21 pm
I used heat wrap, long story short to stop my car catching fire more than twice.
Jebus
Postby vvega » Fri Feb 17, 2006 5:49 pm
Silent Knight wrote:No you've all got it wrong. Wayne is actually a big pussy trying to be kool by having 100s of parts and tools lying around his garage so it looks like he's busy doing something when he's actually not.
no its teh burger that cares
and yeah ive just had to much other shit on to touch anything
i dont think gt4's were ever ment to be daily drivers :D
(perhaps it the way i drive )
as for the hardness test
as yourself this
when you rip yourself open do you
a) cry
b) go get a bandaid
c) go find somethign to stop the bleeding
d) use the bottle of supaglue you have in your pocket(because you do this a lot) to stick all the fleshy bits back in and carry on working :D
v
vvega
Postby bad20v » Fri Feb 17, 2006 5:59 pm
vvega wrote:d) use the bottle of supaglue you have in your pocket(because you do this a lot) to stick all the fleshy bits back in and carry on working :D
v
Funny enough I had to do that exact same thing in Fiji when I cut myself open on the reef while surfing at Cloudbreak. They had no first-aid stuff on the stupid boat!!! But they had superglue, and I used that, waited for it to dry then went surfing again. :D
Im hard. :twisted:
Thank-You.
bad20v
Postby no_8wire » Fri Feb 17, 2006 6:02 pm
option e) Are to busy to notice and keep on working, dont notice till finished what you are doing...
Im always doing that! hehe
no_8wire
Postby riddles » Fri Feb 17, 2006 9:17 pm
E for me. I never notice until it is all over and time to measure how much of the knuckle is missing.
riddles
Postby vvega » Sat Feb 18, 2006 12:49 am
lol i did say gash not just removing skin :D
the differance is a gash will let you know its there because you start painting everthing red :D
Im hard.
see you looked for the first aid stuff :D
i only use teh supaglue cause i cant be $&#$% cleaning up the blood :D
wanna see why you shouldn't hit cv's off with a hardface hammer ??
the 15mm x5mm shard of cage went in at the bottom of teh scar for about 25mm then shot up my leg and into the mussle another 50 odd mm
i went to work for a week after it happend eventually my legg started swelling and i was told(by my partner kelly) to get it fixed :D
and cheers to 10k20v for taking me to the hospital to get my thumb stiched back togeather shortly after this :D
v
vvega
Postby MasCam » Sat Feb 18, 2006 9:23 am
Slashed a tendon in my hand with a machette and didn't notice till I couldn't grip the doorhandle to get into the house... Oh bugger
Shattered a major bone in my wrist, still finished my workout, did my shopping, went to see my mum, cooked my tea and did my house work and only drove myself to hospital when woke up at 3am screaming in pain.
MY WIFE broke her back and walked around for a week before she went to hospital about it and only then because her legs stopped working..
THEN the other day I was struck by a meteorite and instantly vaporised I stappled myself back together and still worked 12hrs the next day, If you told the young people of today a story like that they wouldn't believe you.
NOTE: Only one of the previous stories is made up but which one?the rest we put down to stupidity
p.s the supaglue thing is old hat sparkies use it cos it works better than insulation tape and stops you getting blood all over peoples houses. They use simiar stuff to close you up after operations.
chris
MasCam
Postby no_8wire » Sat Feb 18, 2006 9:34 am
Is it the first one?
:lol:
no_8wire
Postby vvega » Sat Feb 18, 2006 9:37 am
MasCam wrote:Slashed a tendon in my hand with a machette and didn't notice till I couldn't grip the doorhandle to get into the house... Oh bugger
chris
lol i know all this stuff is quite normal
hell the number of time ive woken up at 3 am and in intense pain from arc eye is just stupid
my accidents genrally come from not thinking about what if
i think ive got better with this :D
v
vvega
Postby MasCam » Sat Feb 18, 2006 12:36 pm
Yeah why is it always 3am when you wake up in agony??
MasCam
