Hi,
I'm getting my clutch replaced soon and I'm thinking that there are probably a few other maintenance type items I should be doing while the gearbox is out. So what do you suggest?
sergei wrote:do the seals. One behind the flywheel and 2 on the gearbox (shafts).
Make sure you put the flywheel same way it was, and torque it properly.
