blue top cam shafts 4 gtz
Postby simongtz » Tue Feb 21, 2006 6:54 pm
i have been told that it is a good idea to chuck in some blue top cam shafts into my 4agze engine, i have some to put in but do i have to do sumthing to the shims or whateva. i not sure...would appreciate any help on this matter...cheers
simongtz
Postby Ae92typeX » Tue Feb 21, 2006 8:51 pm
you will want to make sure the shims are still to factory spec.
Ive got the n/a spec here, but someone should be able to confirm if the ze is the same or not first?
Ae92typeX
Postby CAMB01 » Thu Feb 23, 2006 8:27 am
ZE and N/A tappet settings are the same
0.08" inlet and 0.010" exhaust
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Ae92typeX » Thu Feb 23, 2006 8:13 pm
Ive got that for the hot clearances.
cold:
0.15mm-0.25mm (0.006-0.010in) Inlet
0.20mm-0.30mm (0.008-0.012in) Exhaust
Ae92typeX
