AA60 t50 vs AE86 t50
Postby AE85.6 » Tue Feb 21, 2006 8:50 pm
just wandering if the ratios are the same or whether the AA60 one was geared with 13s instead of 14s or something like that ?
or do they have a different size gear on the speedo drive or something as they read like 20kph different ?
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby KinLoud » Tue Feb 21, 2006 10:01 pm
Identical ratios in the gearbox.
The speedo gear on the output shaft depends on the diff ratio of the original car the gearbox was fitted to. Off the top of my head the AA60 had a 3.9:1 ratio (code T312) diff... the AE86 came out of the factory with either 4.1:1 (code T292) or 4.3:1 ratio (code T282). Factory tyres where the same diameter as far as I remember (don't quote me on that!).
Ken
Ham
021 408 863
Postby suberimakuri » Wed Feb 22, 2006 3:41 pm
4.1 in my old aa60.
3.9 is good!
suberimakuri
Postby AE85.6 » Wed Feb 22, 2006 9:01 pm
ah ha i see, cause the extra gearbox was ex a carina, however it had no speedo drive so i used an 86 one, which has made it read approx 20kph low, easy way to remedy ?
AE85.6
Postby Jebus » Wed Feb 22, 2006 9:22 pm
You can get it calibrated, a place in auckland called Speedo Calibration services were gunna do mine, its around $50 from memory. Can find out more if youre keen.
Could well be wrong though, was a while back.
Jebus
Postby AE85.6 » Thu Feb 23, 2006 11:35 am
ye i know you can get them calibrated just dont really know what they do but i thought maybe there was a simple way i could do it like to use a different speedo drive or something,
but ye any details would be awesome cheers,
AE85.6
