what demands the upgrade??? engine mods/transplant.Hachiroku wrote:I'm looking at upgrading the front brakes in my ke70 project for as little coin as possible. If all goes to plan I'll be running an AE86 diff with matching discs. What's my best option for bigger fronts? Is there a bolt in strut swap that doesn't bugger up the suspension geometry? Will I need to upgrade the booster / master cylinder / lines?
the money you'll save by just doing pads, can go towards uprated springs/shocks.Hachiroku wrote:I'm (hopefully) putting a 4age in it. I want it to go, stop and handle at least as well as an AE86.
