Bill Sherwoods 4AGE Info Page wrote:4AGE Blocks
There are basically two types of 4AGE blocks; The ones that are just single cam blocks used for twin cam work and have three ribs on the side, and the small port, 4AGZE, and 20v blocks which have seven ribs. The three rib blocks can only been overbored a small amount, roughly 1mm or 0.040", (82mm total) and the seven rib blocks can go a bit further to 2mm or 0.080". (83mm total) An important note though is that the bigger the bore and/or the more power the engine is making, the more blow-by you'll be getting. I doubt if it's worth boring the block out to try to get more capacity for that reason.
The 20v blocks are reputed to be a slightly different shape around the flywheel area, so that a 16v sump won't bolt straight on. But with some small mods they can be made to fit, I've heard.
The seven rib blocks on the small port 4AGE's also have an oil return pipe on the right-rear from the back of the head. The 4AGZE's & 20v's have the 'bump' in the block for that hole, but it's solid cast metal there instead.
Another good feature of the seven rib blocks is that they have an oil-squirter system that pumps oil onto the bottom of the pistons, thus helping cool them.
There's no other differences between all the blocks.
Any good for 200hp 8500rpm FI?
Ah ha! I see... Cheers.Drifter4ag wrote:blacktop rods
NO GOOD
build the ze up first dont waste your money on the bluetop( as much as i love bluetops)
use the time that you are collecting parts to run the ze engine in
Punter wrote:Drifter4ag wrote: the thin size 20v silvertop rods
