No Air Filter - What sort of damage?
Postby cespenar » Fri Feb 24, 2006 12:49 pm
Well I just replaced my piece of crap HKS air intake (came with the car when it was imported 3 years ago as previous owner stated) with an Apexi Power Intake system, and I discovered that the HKS sponge had all bunched up underneath where you couldn't see and had left a big hole where unfiltered air could get into the engine. So just wndering what sort of damage, if any, would I be looking at? It's a 2JZ-GE Supra and it still runs fine, and I assume that after 3 years of HKS damage if anything were to break it would have done so already, but I don't know if there would be any built up deposits of whatever on the inside or not, and what the best way to clean it out would be. Cheers.
cespenar
Postby Dell'Orto » Fri Feb 24, 2006 1:24 pm
If you've done regular oil changes, it probably wont have done too much. You're lucky its not a GTE, as those shithouse filters dust the compressor wheels :?
Postby Santa'sBoostinSleigh » Fri Feb 24, 2006 1:28 pm
does it seem to burn oil?
your piston rings or the bore may have been worn from sucking in dust
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby cespenar » Sat Feb 25, 2006 2:17 pm
It has been regularly serviced and doesn't seem to burn oil, doesn't blow smoke either *breathes sigh of relief* so I should be OK then, thanks guys. Seems criminal how such poor air filters are allowed to be sold
cespenar
