pyro_sniper2002 wrote:I think youve put the engines in the wrong holes
evil_si wrote:pyro_sniper2002 wrote:I think youve put the engines in the wrong holes
hahaha, the na the batty engine was built for over 500hp, now its weather or not the turbo will support it, i think its too small.
i had actually attempted a 1uzfe batty, but the engine is too high, and to keep under bonnet i would have had to dry sump. and get the steering system redesigned as the front of the cross member had to be removed were the steering mounted.
mad_te71 wrote:do you think you could fit the 2jzgte into the batman ? theres a batman with an sr20det here in chch.
Users browsing this forum: No registered users and 34 guests
