20V cambelt
20V cambelt
Postby BZR4AGE » Thu Mar 02, 2006 11:41 am
A quick question. Anyone knows if the 4age 20V silver top cambelt are the same as the 4AGE 20V blacktop cambelt? apparently they are different, but ain't they the same block and head with just different internals?
the reason i am asking is because i bought a racing cambelt from overseas, and i think they gave me the silvertop belt instead.
BZR4AGE
Postby Mr Revhead » Thu Mar 02, 2006 1:11 pm
yes they are different
you bought a what????
why?
Postby neo » Thu Mar 02, 2006 1:44 pm
'it probably one of those fancy gates green ones...'
neo
Postby BZR4AGE » Thu Mar 02, 2006 3:42 pm
bought the TODA timing belt.
Remember I was going to fit the TODA kit, well is still going to go ahead. I want everything to be safe so i bought one. hahaha, when i bought it in Hong Kong, the guy said is the same. I knew he was wrong. i guess is time for me to sell i then.
Thx revhead.
BZR4AGE
Postby RedMist » Thu Mar 02, 2006 4:04 pm
Goat Harasser, is it the crank pulley or the cam pulley's that are different to require the alteration in belt?
I know with the colleciton of every 4age part under the Sun, I'm going to be caught by this one... one day.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Thu Mar 02, 2006 4:18 pm
im not sure on the pulleys.... but the blacktop has that auto tensioner and is longer i think, by a tooth iirc
so it maybe the pulleys, the tensioner or both
Postby BZR4AGE » Tue Mar 07, 2006 7:03 pm
Hey guys. I was selling the belt in trademe, but a guy told me if i use the silvertop tensioner, then my toda belt would be fine, because if i use the silvertop tensioner, then their wouldn't be a 1 tooth difference. Is this true? will it work on my blacktop? How much is a tensioner cost usually? Sorry I dun really know wht the tensioner is. Cheers guys
BZR4AGE
Postby sergei » Tue Mar 07, 2006 7:18 pm
I think silver top tensioner has different mounting position
Postby matt dunn » Tue Mar 07, 2006 10:55 pm
sergei wrote:I think silver top tensioner has different mounting position
I imagine that you would have to use a complete silvertop oil pump assembly to get that to work.
Postby sergei » Wed Mar 08, 2006 7:44 am
Also silvertop oil pump has timing mark in slightly different position as well.
In my opinion it is too much hassle for a just a cambelt.
Just get genuine for 40-50 odd bucks and it will work fine.
