mandrel Vs crushed
mandrel Vs crushed
Postby Infinite » Thu Mar 02, 2006 7:03 am
Ok so i have the choice agenst a mandrel or crushed exhaust.. Is there going to be that big of a difference on a 2ltr curren? its geting extractors fitted has a k&n and cold air box but later on i want to get more power out of it, but whats going to be worth it to me? im not trying to get the best time down the strip i just want a nice car that has some balls when i need it.
Lots
Infinite
Postby Ae92typeX » Thu Mar 02, 2006 8:21 am
Ultimatly the mandrel is better, but in seat of pants kw power, you probably wont notice to be honnest.placebo pants may offer a different opinion. If you do have more plans for later though, and the extra cost does not bother you than go mandrel.
Ae92typeX
Postby $CENSLS1$ » Thu Mar 02, 2006 9:10 am
Basically exactly what AE92typeX said.But also if you are looking at future mods (turbo etc) then go with the mandrel but if not then I say stick with the crush bent,unless of corse you have the money for the mandrel...
I think the thing you should be looking at is the sizing... ;)
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
Postby Infinite » Thu Mar 02, 2006 7:28 pm
i was going to go 2.5inch and i will be puting a 3s-gte engine in later... when i can find one...
Lots
Infinite
Postby Malcolm » Thu Mar 02, 2006 8:00 pm
2.5" mandrel bent would be recommended for a 3sgte, it will be major overkill for what you have now though and your car will be slower.
Postby Infinite » Thu Mar 02, 2006 8:50 pm
what would u recomend for the car now? if i was to put a system in for now it would be crushed
Lots
Infinite
Postby Caveman » Thu Mar 02, 2006 11:08 pm
You want the system to be header back and about 2'-2.25. Just use mild steel, very cheap. Won't make much difference in power, i bet it'll feel faster because it'll be loud 8) Main restriction is in the end muffler and expansion chambers, not as much in the cat so if you want to be all green keep the cat. 4AGZE one is very good, 2.5' inlets/outlets, could be the same on most others, havn't really compared.
I guess you could almost argue that some cats are less restrictive than some resonators. Cat just has slots, which would probably help straighten flow and has a similar flow area to the inlet. Some resonators cause lots of turbulance and have poor flow dynamics i.e expand the gas then force through a smaller hole without any gradient. I have heard exhaust shops saying a cat is only 1% of the total restriction. Also with a resonator the flow capacity decreases with RPM as the turbulance increases.
Lots of room for discussion here :lol:
For turbo cars go 2.5'-3'
Caveman
Postby Jazza » Fri Mar 03, 2006 7:44 am
Stick a 2 and 1/4 inch on it. And make sure your tip aint too big...
Anything bigger and you may start losing backpressue on your current engine.
(Although, a 2 and 1/4 inch is too small for a 3sgte right?)
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby Malcolm » Fri Mar 03, 2006 9:47 am
please don't use the word backpressure :)
2 1/4 will be too small for a 3sgte, although if it's relatively stock then a good mandrel bent one might not cause too much restriction
Postby Caveman » Fri Mar 03, 2006 9:56 am
Jazza wrote:Stick a 2 and 1/4 inch on it. And make sure your tip aint too big...
Nah its not backpressure, the gas expands too much and slows down causing restriction.
Caveman
Postby Ako » Fri Mar 03, 2006 12:26 pm
Holy jesus I finally understand it all now :oops:
Ako
Postby 4TEAZN » Sun Mar 05, 2006 12:55 pm
i wouldnt bother with the mandrel bent on ur current setup as ur probably not gonna have it long anyway so id go for just a press bent 2-2.5" but when u get the 3sgte go for a 2.75" - 3" mandrel bent and u will notice the difference as mandrel bent flows around 30% beter then press bent.
4TEAZN
Postby MAGN1T » Sun Mar 05, 2006 11:22 pm
Have any of you guys actually used a pipe bender?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Caveman » Sun Mar 05, 2006 11:26 pm
MAGN1T wrote:Have any of you guys actually used a pipe bender?
Steve
Yes, your point being?
Caveman
Postby Ae92typeX » Mon Mar 06, 2006 8:17 am
Steve
yep, sure have. again, the point of the question?
Ae92typeX
Users browsing this forum: Bing [Bot] and 12 guests
