Battery, which one to get?
Postby Inane » Mon Mar 06, 2006 1:31 pm
ok its come that time where my current car battery is due for retirement,
(at least it better be cos the battery is dying that the batt is going flat after 4 hours ish- I really CBF dealing with a new alternator or an earthing problem right now)
What I want to know is what batteries do people recommend?
the battery I currently have is much smaller than other batteries people seem to have, however up until now it has worked flawlessly it wasnt new when I got the car (came with it from japan) and its been in the caldina for over 70,000 k's since I got it.
so I want a decent reliable small form factor battery that is preferably semi-sealed, and reasonably easy to get (better yet one with a charge indicator light as well)
What are peoples recommendations?
Inane
Postby sergei » Mon Mar 06, 2006 1:45 pm
If money is not problem get either Optima or Excide Spiral Cell bettery, I have Optima's (yellow top 1000CA one) in both of my cars and do they crank!
Actually after 12 month off road without recharging it actually started the car like fresh.
Postby Punter » Mon Mar 06, 2006 2:34 pm
No need for an Optima if it just for a car, (ie. no 5kw stero to run) any branded batterey should be fine, try get one with a 3year warrenty.
Punter
Postby Inane » Mon Mar 06, 2006 3:25 pm
I want one that Ideally I can leave my stereo going without the car running for half an hour (say while i wash the car) without it going flat.
also want a smaller form factor.
Inane
Postby B1NZ » Mon Mar 06, 2006 5:20 pm
i got an AC Delco one from the battery shop, about 2 doors away from supercheap in the hutt, Sealed with the indicator gauge, qute small, cost $116 inc GSt for memory with 2 year warranty
seems to do fine, unless you are running 10,000 subs the optima ones etc seem like a bit of an overkill
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Inane » Tue Mar 07, 2006 10:44 am
B1NZ wrote:i got an AC Delco one from the battery shop, about 2 doors away from supercheap in the hutt, Sealed with the indicator gauge, qute small, cost $116 inc GSt for memory with 2 year warranty
sweet. thats what I am after. $116 inc gst is much better than $356 inc gst on special,
Inane
Postby GTCRSHR » Tue Mar 07, 2006 1:45 pm
hey was the $356inch gst for a optima ?
if so who quoted you that ? and for which model optima
Nothing to see here ...
GTCRSHR
Postby Inane » Tue Mar 07, 2006 4:52 pm
GTCRSHR wrote:hey was the $356inch gst for a optima ?
it was the Red top optima and its $354.67 ex gst im afraid! (just took another look)
the yellow top is $400 ex gst
http://racerdirect.co.nz/catalogue.asp? ... ategory=47
Inane
Postby GTCRSHR » Tue Mar 07, 2006 5:03 pm
cheers for that,
that price is about right to most people that walk in through the door, can be had for about $350-$400 usually (yellow top) in auckland if you know where
GTCRSHR
Postby GTCRSHR » Tue Mar 07, 2006 5:04 pm
oh and Bosch batteries from super cheap are good value and last for good amount of time !
GTCRSHR
Postby sergei » Tue Mar 07, 2006 5:24 pm
On tardme they sell Exide Orbital 1000CA 50Ah for 245 buy now. Pretty good price for what they are...
